Results 1 to 16 of 16
Thread: Day One for TFP
    david23's Avatar
    Mar 2015
    Memphis, TN
    12
    Day One for TFP
    I love what I am seeing here, so I'm in! While waiting for my TF-100 to arrive, I had my local pool store (yes, sorry) test my water and my CYA was 160 (curse you trichlor tabs). So I spent the week draining and refilling. I dumped in three 121oz bottles of Clorox to ward off the algae (none visible) while I get set up (I sure hope that was okay to do).
    I ran my first (shaky at best - all results are suspect) TF-100 test battery this morning. The fresh new water looks very nice.
    FC 13
    pH 7.8
    TA 120
    CH 175
    CYA 45
    CSI 0.12
    Water temp 69 degrees
    I am unclear whether to add even more bleach for an initial SLAM after draining & refilling so much. After this test I added 48 oz muriatic acid to rein in the pH.
    I am concerned about the CH and CSI, but I will wait until I get some guidance from you.
    When everything is in order, I have Borax and MA standing by for the big day.
    Thanks for holding my hand while I learn these new skills. - David
    TF-100 test kit, 33k gal, IG gunite, cartridge Purex Triton CCP 320, 1 HP WhisperFlo pump, pool installed 11/15/02, Polaris 280. Separate IG spa.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,668
    Re: Day One for TFP
    You did it! You are SO far ahead of the game it is not even funny!
    -found TFP!
    -Ordered good test kit!
    -did tests!
    -Asked questions!
    -became a member-bonus!
    I will let others help you out with the numbers. I have a vinyl pool so my "rules" are different than yours.
    I just wanted to say WELL DONE!
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Day One for TFP
    Welcome!
    First, the bad news... when FC is above 10, the pH will read falsely high. So there's a good chance your pH wasn't really 7.8 and now that you've added acid, it might be too low. The high-ish TA will push that back up pretty quickly. Time will tell.
    The good news is that CH will come up all by itself as soon as the weather warms up and you start losing water to evaporation. Water evaporates, but CH remains. With the acid you've added, TA will lower some. It should not take aggressive action to reduce it.
    The best news is that nothing is horribly out of whack, nothing that will require immediate drastic action.
    I suggest you wait to do the borates -- if you choose to go that route; I haven't -- until you've mastered the rest of it. There's no need to add another variable to the equation just yet. It will only take you a couple weeks to learn your pool's personality and get used to the routine. Seriously, once things are balanced, your daily pool care is about as difficult and time-consuming as brushing your teeth. Brushing the pool weekly takes a bit more effort
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Day One for TFP
    David,
    Welcome to the forum with a most excellent first post. Congrats on taking a big first step and running with it.
    Depending on your makeup water to the pool your CH may come up quickly enough. Run a CH on it and report the number please. The pH is good where you are right now. In 33k gallons and your TA, it should be fine with the 48 oz addition, or not too bad at worse.
    Did you have Algae when you started this process? If not, you won't need to keep up SLAM levels of FC, but that's fine where it is right now as well. Don't increase it yet.
    Essential Links:
    Re: Day One for TFP
    I would suggest doing a combined chlorine test and an overnight chlorine loss test. As long as your cc is 0.5 ppm or less and you don't lose more than 1 ppm overnight, you should be good.
    Support the site
    david23's Avatar
    Mar 2015
    Memphis, TN
    12
    Re: Day One for TFP
    kimkats - thanks!
    Richard 320 - So I basically "pool-stored" myself. Drats. Your post made my head spin a bit. Sounds like I need to lay back and just check chlorine & pH daily for a week or so...
    Patrick_B - The CH I ran came back at 175. I may be misunderstanding if you are asking me to run another or a different test. No algae since last summer. With the CYA at 160 I now understand why last pool season was a nightmare.
    JamesW - I will return to Pool School and get going on the tests you advised. Thanks
    Thanks for the amazing support and encouragement. I regret spending the last 9 years without your help.
    I look forward to adding the borax, but I will follow Richard320's guidance and wait.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Day One for TFP
    For CH, I am asking what the level is from your tap, or same water you use to fill the pool.
    If that makeup source has much CH in it at all, it won't be too long before you have enough CH in the pool to be in range, and improve the CSI. Not that you should be frantic or tightly focused on CSI, but you mentioned it. Run a CH on the same water you used to fill the pool.
    Essential Links:
    david23's Avatar
    Mar 2015
    Memphis, TN
    12
    Re: Day One for TFP
    Thanks Patrick_B
    My fill water CH is only 50. Hope that will help as time passes.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Day One for TFP
    You could use a little powdered chlorine in the form of calcium hypochlorite for a while/occasionally. Sold at hardware and big stores like Walmart. The CH will increase fairly slow at 50 ppm in your makeup. Or buy cement accelerator in the the form of Dow Flake etc. Great problem to have so count your blessings. Mine is opposite of yours, and that's not so good.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Day One for TFP
    David,
    Welcome to TFP.
    Looks like you have a pretty good grip on things and no doubt in a short period of time, you will experience the clearest cleanest pool you have ever seen and for way less money that what you've been spending on the "pool chemicals"
    Divin Dave,
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    Re: Day One for TFP
    Welcome, you'll be happy you decided to go the TFP route. Now for this cool weather to move on so I can get my pool open
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: Day One for TFP
    Welcome to the forum David
    Don't worry about Pool Storing yourself. You're on the road to being Pool Store free
    Solar Blanket, Well Water, Borax Added. 76
    Casey's Avatar
    SW PA
    10,461
    Re: Day One for TFP
    Hey... Where's the pics?!
    Welcome to TFP! All of this will click n you'll be helping others here someday soon.
    david23's Avatar
    Mar 2015
    Memphis, TN
    12
    Re: Day One for TFP
    Sorry Casey - missed your post. Here you go:
    Jul 2012
    Tallahassee, FL
    30,668
    Re: Day One for TFP
    Oh how pretty! That looks like fun!
    Kim
    Ncdamsel's Avatar
    Jul 2015
    Garner ,NC
    65
    Re: Day One for TFP
    Nice ....nice pool
    13,995 gallons 24 X 52 / above ground pool.../.SWG/ sand filter/ vinyl liner
