Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Cleaning Cartridge Filters
    Stony Lake, Michigan
    10
    I have washed out my cartridge now 3 times and it is time to "soak" it to get rid of body and tanning oils etc. that regular washing won't remove.
    I know the local pool supply would be more than willing to sell me their soaking product but is there something stashed under the kitchen sink that would work just as well?
    "It's All About The Duck"!
    Ohio
    87
    Hi Cabana Boy,
    You are right on something under the sink, at least that's where ours is. You can mix up some dishwasher powder soap in a bucket of water big enough to cover the filter and soak it. I use 2 cups of powder to mix up the 5 gallon bucket and soak at least overnight. And then remove the cartridge and rinse well just like your normal cleaning. I only do this about twice a season at the most. Usually I can get the filter clean with just a straight tip on my garden hose.
    24'x54" Sharkline Matrix by Wilbar International, 15,200 gallons (2015)
    Jacuzzi 75 sq ft Cartridge Filter 1 hp two speed pump
    Solar Heat with Goldline GL-235 Controller
    Intex Krystal Clear Model 28669 SWG
    TF100, SampleSizer, and Speed Stir
    mas985's Avatar
    Pleasanton, CA
    11,742
    I use Simple Green. It doesn't suds up as much as dish washing liquid and seems to work well.
    Mark
    Guest
    Mas985, no one is suggesting using dishwashing liquid but rather automatic dishwashing detergent powder,which is mostly TSP. It does not suds at all actually. Unicel Filters recommends it for cleaning carts on their website. This link gives complete instructions.
    As far as rinsing it off I have found that one of those short, brass high pressure garden hose nozzles (the 3" non adjustable kind with the small center bore) works the best at hosing off a cart. They only cost about $3 and, IMHO, do a better job than the two fancy special cleaning wands that I bought to clean my carts.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Sorry, I read it wrong.
    Mark
    new2pools's Avatar
    Hampton Roads/Virginia
    180
    Dang, I read it that way too.
    mas985, is the Simple Green sold at pool stores for this purpose or is it something else?
    Thanks
    27' Round AGP, 17200 GAL, 2 HP/2 SPD Pump/Cartridge Filter.......BBB!
    mas985's Avatar
    Pleasanton, CA
    11,742
    Simple Green is a general purpose cleaner sold at most home stores including Home Depot. I use quite a bit of it since I soak 4 filters at once so for me, it is a bit more cost effective than some of the other methods and it is enviro-friendly.
    Info: http://consumer.simplegreen.com/index.php
    Buy: http://consumer.simplegreen.com/cons_buy.php
    History: http://en.wikipedia.org/wiki/Simple_Green
    It is also used to clean up oil spills so it breaks down sun tan oil pretty well.
    Mark
    10
    Thanks for all your replies. Debby has plenty of dishwasher soap so I will give it a try.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Blaster 1000/2000/3000
    Has anyone seen these or tried one out? They're a bit expensive but they appear to work well....maybe.
    www.poolproducts.com/-i-ACC-NTRI-BLASTER3000.htm
    P.S. There's a video demo on the website.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Ohio
    87
    I have looked at that exact item and bought the water wand instead. And I think the result would be the same, it looks better in the video. You are still limited to the water supply pressure to clean the product (~52 pounds here) even though you are spraying it from small holes to increase the pressure.
    After trying several methods to make rinsing the cartridges easier or better, I too ended up with a straight bore tip on the hose being the best. As Waterbear stated above this type of nozzle is reasonable in price and works pretty well. I even found a tip with a built-in on/off control and very small bore that works the best. Yes I do get wet while spraying the water but not to bad if I take my time and don't spray straight in front of myself. Your Mileage May Vary
    Guest
    $169 for the blaster vs. $3 for a brass high pressure nozzle? HMMM, let me think which I want to go with.
    10
    I was told by my pool installer to use my pressure washer (1500 psi) to clean out my filter. Seems a little extreme to me. I thought the hose nozzle did a good job and it didn't damage the media.
    Guest
    Most cartridge manufacturers will tell you NOT to use a pressure washer because you can blow a hole in the polyester material and ruin the cart.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Quote Originally Posted by waterbear
    Yes, I agree, $169 vs. $3 is pretty much a no brainer. I was just wondering if someone out there has one or knows someone with one so we could get some feedback.
    I doubt that no one that has one is going to admitt it now.
    Quote Originally Posted by TripleB4me
    Well, after cleaning the little wimpy intex filters for 3 or 4 years, and getting that green goo sprayed in my face a LOT, I'd have to say that if I had the money, I'd have the blaster! I cannot imagine cleaning a full-sized cartridge! yuk. ((When I ever get my pool, it will have a sand filter!))
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    It's a pretty sloppy job that's for sure. While the Blaster is a pretty high priced reconfigured sprinkler it sure looks like a good idea......if it works as well as the video suggests.
    Jun 2007
    McKinney, Texas
    5
    hate to bump this thread, but I've got a question based on this discussion.
    I've been told (by both the pool builder and Leslie's Pool Supply) to soak the filters in a 1:4 solution of muriatic acid and water, after hosing off the debris.
    My filters are the STA-RITE System 3 - 450 - S8M150 setup, and at $400+ for the pair, trying to keep them going at this point is important.
    Thanks in advance!
    Acid and automatic dishwashing detergent remove different kinds of things. For most people most of the time automatic dishwashing detergent works better but there are times when acid is just the thing.
    Ft Lauderdale, Florida
    1,455
    You'll want to degrease it first before soaking in muriatic acid. Acid will tend to lock the greases and oils into the filter element, making it less effective.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
  20. Back To Top    #20
    Guest
    Acid washing a cart without soaking in a degreaser first usually means that the cart ends up in the trashcan instead of back in your filter. The organics will harden on the filter material and when you use the filter your pressure will rise very fast!
    I know Leslie's sells replacement carts! Does your builder also?
    Think about it!
