Thread: Timing Questions
    Feb 2015
    Phoenix, Arizona
    3
    Timing Questions
    Hey guys,
    I had a couple general questions regarding recommended timing on chemicals.
    1) How long do I wait after adding chemicals before adding other chemicals of different types?
    2) How long do I run my pump after adding chemicals to make sure the water is ran through enough?
    3) How long do I wait after adding chemicals before retesting?
    4) How long to wait to swim after adding chemicals?
    Thank in advance.
    10,000 Gal, IG Pebble, Hayward Pro Series Sand Filter, 0.75kW Hayward Super II Pump, Rebuilt 2012 (California Pools), Baracuda MX-8 Cleaner
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Re: Timing Questions
    In general, just 30 to 45 minutes with the pump running throughout.
    If you are adding Chlorine/bleach in normal doses 30 minutes is fine. If you are adding Chlorine at SLAM levels, you will need to confirm you are in range for your CYA levels before getting in the pool.
    Do not test Ph if your Clorine level is above 10ppm as FC levels above 10 mess up the Ph test.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    For all of the waits, 30 minutes for liquid chemicals, an hour for solid/powdered/granular chemicals. Except that salt should be 24 hours, and CYA should be a week before testing and neither requires a wait before swimming.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    i dont add calcium hardness and baking soda on same day
    i once added them too close together (as in immediately) and it made my water cloudy for days
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    +1 on Jason's timing.
    Solar Blanket, Well Water, Borax Added. 68
