Results 1 to 12 of 12
Thread: Considering Returning my Z5
    Mar 2015
    Jupiter, FL
    9
    Hello TFP!
    So I picked up a Z5 from Epic Pool Supply about two weeks ago. After reading all the reviews it sounded like the Dolphin Z5 was the way to go. Unfortunately, I'm feeling really underwhelmed and I'm wondering if I have too high of expectations or if I genuinely received a dud unit.
    First, let me say that it's serious pollen season here in South Florida and I've been dealing with water clarity for a few weeks. The stuff that settles is fine and you have to vacuum really slowly when done manually.
    My issues:
    The Z5 makes a path in the pool where the only clean trails are where the foam rollers contact the surface. It does pickup more via multiple passes but does not leave a full clean streak on the bottom. The water becomes extremely cloudy after it runs.
    The robot completely misses two corners of the pool. Large areas, one 10x5' the other probably 7x3'. Even after multiple runs.
    The cord gets so twisted it's like a cruel joke. The unit seems to turn only one direction, counter clockwise, probably 90% of the time.
    It never makes it up on my stairs.
    The filters are cleaned and they do get dirty after the unit runs. It is "cleaning" some of the stuff out of the pool. Am i expecting too much out of this robot?
    Edit: I have not called Maytronics yet.
    18'x36', 24k gal IG; Pentair SuperFlo 1HP 2 speed pump; Pentair 200 Cartridge filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Considering Returning my Z5
    None of them do stairs well that I've heard. I don't know about the corners he's missing, but I would say give him time. I e never seen mine miss an area yet. I have an M5, but same difference there. I'll give you the cord tangle. Not terrible like that you describe, and it never hinders mine as far as I can tell.
    Maybe pollen is getting through the filters some. Are you using the fine cart filters or the screen/mesh ones? It sounds like they are getting full of something which is what you want. I don't have pollen, but I get lots of fine sand and very fine dust. The carts pick up everything pretty nicely. Not sure what you expect, but I would try more before sending it back. If he always misses the areas, perhaps something is wrong. Based on seeing mine, I can't imagine that happening. I have a pool of the same size too.
    Essential Links:
    Jun 2014
    Rogers, AR
    424
    As a new owner as well, I can tell you it really needs to learn your pool. I have run mine about 10 times now and I really am starting to see a difference in how it is working in my pool.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    Mar 2015
    Jupiter, FL
    9
    I feel like I've run it quite a bit. Does yours pick up most debris in a single pass?
    The cord tangling is super frustrating. I would say that it gets to the point that it hinders the movement. Does anyone else have this problem?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Most yes, but not always 100% of everything. But, by the time he is done, I have never been disappointed. My cord does get twisted, but I've never seen it hold him back at all.
    Which cart filters are you running in the Robot?
    Essential Links:
    30,415
    I have a Dolphin Premier with, I believe, the same Super Duper anti=tangle cord and it doesn't work worth a toot.
    Jun 2014
    Rogers, AR
    424
    Mine has done well since day one but I definatly see a difference the last couple of runs. In my instance, it totaly ignored my shallow end. Now I see it spending a lot more time in the shallow end and the way it maunuvers around my pool. I was kinda underwhelmed at first but I am well on the way to being very impressed.
    My cord never has tangled but I lay it out in the pool I don't know if that makes a difference.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It does do better if you stretch it out first Chrissy, I agree.
    Essential Links:
    Oct 2007
    Parkland, FL
    752
    If its only turning one direction, it sounds like something is broken, potentially one of the motors is not working. That would cause the cord to tangle for sure. You could take the remote and see if you can turn it in both directions.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Mar 2015
    Jupiter, FL
    9
    And... I'm done. This thing has no suction power. Just keeps clouding up my pool and within 2 days it all settles back down. It even falls down from the sides rather than crawling down. If it's not defective then it's a terrible product. Very unhappy that Epic is going to try and hit me for a 20% restocking fee.
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by FL Gator View Post
    why don't you exchange it?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It sounds to me like you somehow got a lemon.
    I would exchange it for another. I know they work and based on what you're reporting it really sounds like you got a defective one.
    As for clouding your pool, there is likely something else going on that no cleaner will take care of. Can't say for certain, but you never did answer what filters you are running when it does this. If you have dust, and you're running the wrong filters that could be part of the issue.
    Honestly, with a cartridge filter system on your pool there shouldn't be anything in there to cloud the water.
    Essential Links:
