Results 1 to 10 of 10
Thread: First time home buyer- above ground pool
    Apr 2015
    Portland, TN
    3
    Hello all,
    My husband and I will be first-time home buyers buying a home with an above ground pool. The home inspector says he doesn't inspect pools, but he'll check the motor and the electrical to make sure it's in working order. The current owners were elderly and I'm not sure they used the pool at all in the 4 years they lived there. It does not have a cover. Should we hire a pool inspector? What else should we know going into this endeavor? Neither of us have ever owned a pool before.
    Thanks so much!
    Clueless
    No idea what I'm doing- Above ground with deck. AquaTools Hi-Rate Sand Filter- AT3125, AquaTools Century LASAR Pool/Spa Motor- AT2412710.
    Orlando, FL
    690
    Re: First time home buyer- above ground pool
    Is the pool being included "as is" or is it a deal breaker if it has issues? From the little I know, AGPs are usually included "as is". If the potential owner doesn't want to deal with it, the existing owner will just sell it or give it away before the sale. My point is, if it's "as is" I would accept what the inspector is willing to do and not pay someone to inspect the pool separately. If it's holding water, you can check how level it is and determine if it leaks. Liners and pumps are not that expensive. If there is rust or damage to the walls that you feel make it an unsafe pool, get the existing owner to get rid of it before you close.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    I recommend getting a separate pool inspection. The pool might be totally fine or need expensive repairs, and it is good to know that in advance.
    Owning a pool can be very overwhelming just at first. Once you get into the routine it can be quick easy and a real joy, but just at first it is a lot to learn all at once.
    Apr 2015
    Portland, TN
    3
    Thank you all! The pool is included as-is. It is not a deal breaker at all. We weren't seeking a pool by any means, it just happens to be part of the deal. We're going back to the house tomorrow so I'll take some pictures and get a better grasp on what we have going on. I'll see if you all can give us some more insight then. Thanks again!
    Casey's Avatar
    SW PA
    10,423
    Welcome to TFP!
    Please do post pictures of your new pool. In your spare time, take a moment and read up in Pool School... The button at the top right of every page. Start with the ABC's of Pool Water Chemistry and then look into Test Kit Comparison.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum
    That's a big step, first house and first pool
    Solar Blanket, Well Water, Borax Added. 68
    Apr 2015
    Portland, TN
    3
    Oh boy, We bought the house, and the pool. Unfortunately the sellers did not fulfill the repair contract item- replacing missing pieces from pool filter and pump. We have absolutely no idea what we're doing. The sellers told us all of the parts they removed to "winterize" were in the garage in a baggy. We finished filling the pool up this morning and there was water coming out of the pump and out of the filter. My husband found a piece that fit in the pump, but no such luck with the filter. Our filter is an AquaTools AT3125 and it appears to be missing (from my research online) the drain cap, and I'm guessing an O ring. I'm thinking we're going to have to order that part online. I'm really worried about turning the pump are for the first time, though because we're not sure if it's still missing any pieces. The pump is an AquaTools AT2412710. I'll upload some pictures. How do I tell how big the pool is? I literally have NO idea what I'm doing. I think we're going to hire a pool guy to come look at this mess and help us getting started. Oy vey! Any and all advice is extremely appreciated!!! Thanks in advance!11216083_10207023106475742_353927994_n.jpg11216396_10207023106675747_1607635216_n.jpg
    Casey's Avatar
    SW PA
    10,423
    Please take a pic of the pool. How many post/uprights are around the pool.
    Mar 2015
    Harvey, LA
    300
    For your future reference, although the pump as a whole might be aquatools, the motor is AO Smith based on the picture, and you can get parts for it separately from the pump assembly...it just opens your options when looking for parts, doesn't have to be aquatools specific.
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Having someone come out is likely a good idea and them might have the caps and plugs you're missing with them.
    Getting the pool running is the first step but I wouldn't have the person start adding anything to the water. Have you been reading any of the Pool School articles on your pools care ??
    http://www.troublefreepool.com/conte...at-is-tfpc-bbb
