Thread: When is the best time to open an inground pool in central New Jersey
    Sep 2014
    Wayne,NJ
    4
    We have a pool in the Lanoka Harbor area of NJ,just wondering when is the best time to open it and start it going ? I think it might be before the water temp gets too warm and alge starts growing? What tempature would that be ? Today is April 3,2015. Pool tempature now is about 55 degrees.
    Inground Pool 16x32 vinyl liner 18,500 gallons, 4ft. to 6 1/2 ft. Hayward sand Filter,single speed pump.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: When is the best time to open an inground pool in central New Jersey
    Opening at 60 is desirable, but it's really a matter of convenience. Earlier opening means longer time maintaining with no swimmers, but later opening means the pool will be messier to get cleaned up.
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Several factors are involved in the decision. Yes 60 degrees is a suggested point to open. But timing is also based on personal preference factors. Just test your FC to ensure you have an appropriate level to prevent algae.
    I started weekly testing for FC and temperature two weeks ago. I plan to make additions to keep FC at 7, just above my target of 6 based on CYA test last Fall. I will probably test CYA later today to make sure I'm still between 40 and 50 or if I need to adjust my FC target downward. My pool was at 55 degrees on first test and 57 for second test.
    I will probably open it on May 2 or May 9 when it hits mid 60s. My problem is keeping up with all the Spring tree dander once the cover is off.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Jun 2013
    Augusta, GA
    90
    No advice to offer, just chimed in to say that I grew up in Forked River.
    30'x52'' AGP 21,000 Gallons
    TWM 2.64 SF Sand Filter w/ Century 1.5 HP Pump
    BBB'er for life!
    TF-100 Test Kit
