Thread: planning to add SWG
    planning to add SWG
    Hi,
    I'm looking to convert my plaster pool to SWG. I just started planning it after deciding between liquidator vs swg.
    Currently using Chlorine tablet, which is driving my CYA up too much. I had SWG on my previous home. This pool was build somewhere in '99, and came with the house.
    Also it comes with something call Natural Balance Catalyst.
    I found little information on this item. I think it's already discontinued item and I don't use it anyway.
    So I am thinking, this item looks like it's installed after the heater and looks like a return line to the pool/spa.
    So instead of cutting PVC, this look like a possible location to replace it with the SWG cell?
    But I can't find anything about this catalyst, like what kind of connector does it use. Is it a standard connectors? Can I just mount a SWG cell to it? Or do I still need to cut off the ends? Anyone have experience with this Catalyst thingy?
    regards,
    elteebee
    14.5K gal, spa, plaster,waterfall, 1.5hp pump, chlorine tablet
    Re: planning to add SWG
    There is some chance the unions might match, but it is very unlikely the distance between them will match. You will almost certainly need to cut it out to install the SWG.
    thanks for the info. Guess i need to find out more of the size of the pipe/union and length of which ever swg I plan to get.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Catalyst Natural Balance is a Jack's Magic Product. Mineral based water sanitation.
    http://www.jacksmagic.com/pdfs/CAT3001TAB.pdf
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Feb 2014
    Upstate, NY
    390
    I would be surprised if the unions fit (threads) converting to SWG if that is what you are asking? You are going to have to cut the pipe and install new unions with the new SWG. I'm pretty sure Hayward/Goldline Aquarite SWG's have a patented thread which will not fit other unions. Please confirm other brands. It's very simple to cut PVC and it would make for a better install in my opinion.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    thanks elwood58, I found that too. Was hoping to find the union sizing and such.
    I'm glad I ask this forum, since it sounds like doesn't really matter now, if the SWG unions are patented. I'll need to cut it anyway then. I'll plan it a bit and maybe post on a new thread on my plan and see if my plan is ok.
    I'm thinking of getting the Circupool SJ-30 since my pool is just 14.5k and shaded most of the time. Wondering now if that's an overkill or the SJ-20 would suffice.
