Page 1 of 149 12341151101 ... LastLast
Results 1 to 20 of 2980
Thread: What did you do to your pool today?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Not much here yet. Cover still on, but peeled it back again and ran some basics. Been crystal over the winter, but added a little Cya to bump me up from 30. Added a little Acid and Bleach. As soon as my trees drop some tassels, the cover will come off.
    What did you do to yours?
    Essential Links:
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: What did you do to your pool today?
    I don't close for the winter. Water is balanced and has been all winter. Just running the pump, as pollen is thick and trees are dropping lots of stuff. Awaiting water temp of 73 or 74, then I'll jump in. Right now water is 70 degrees.
    Just started with BBB in Spring of last year. If it wasn't for that I'd be throwing Shock, Phosfree, and all kinds of other stuff in there that the pool store would advise.
    As it is, I don't have to do very much. Just add bleach and MA as needed. Pool looks like the avatar pic right now.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Our Pal WoodyP has been telling me about your pollen woes out in the far East. We will have our dust storms soon enough. A little bit kicking up today.
    Essential Links:
    Aug 2014
    Shallotte, NC
    693
    Half filled the new liner with water! Tomorrow starts a new spread sheet on chemistry......
    Dec 2012
    Manassas Park, VA
    199
    Cut down a large branch from one of the several Birch trees that overhang the pool as I try to minimize the amount of debris that constantly falls into the pool. Other than that pool is still covered with water temp around 46.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    S1ngram's Avatar
    Jun 2014
    Chrisman, Illinois (East Central Illinois)
    301
    Nothing today because of rain, but yesterday I put down weed barrier, edging and small river rock around most of the base of my pool. In a couple of weeks, I have some guys coming out to pour a concrete pad for my pool equipment.
    27' round Seaspray Evolution, AG, 17,100 gallons, Pump: Hayward Power-Flo Matrix Dual Speed 1.5 hp, Filter: Hayward Pro Series High Rate Sand Filter, June 18, 2014, Kreepy Krauley Lil Shark, TF-100 test kit, Intex Krystal Clear Saltwater System
    Mod Squad pooldv's Avatar
    DFW, TX
    24,259
    Checked the temp am it was 75, checked at noon it was 76 and solar panels are blasting heat into the pool. I have also emptied my skimmer baskets about 2,378 times today and the pool surface is covered with some tree doodoo. But, the water under the tree doodoo is sparkly clear.
    Last sunday I cleaned and replaced filters with the pentair carts that i don't like. Wednesday I cleaned and put the Pleatco cartridges that I do like. Before that I did full meal deal TF100 tests. Added 3 bags o salt and some CYA to get everything in line for swimmy-swim-swimtime. Everything else was perfecto and ready to go.
    Now all my pool needs to be ready for swimming is more hotness!
    Jan 2012
    'burbs of Augusta, Georgia
    7,180
    Opened up cover and tested- eeeeek~ 0.5 FC,0 CC...last month the FC was 7.5. Pool is crystal clear as always. I haven't added anything since last fall, we even turned off the SWG and just let it drift down over the winter. I've opened and tested throughout fall and winter but never got such low CL before. Today-Added a gallon of bleach, did a little scooping and a bit of brushing, but have to wait for Skippy to come home to do more of the brushing labor and crawl through the overgrowth to get to the equipment and turn the SWG back on.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,274
    Quote Originally Posted by Patrick_B View Post
    Yep----been dipping oak tree fronds out most of the day! Bumped up CYA yesterday to 40ish level. Test again in a few days to be sure. Was too low to be accurate.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Our water is 77° today....we went for a brisk swim!
    DFW, TX
    24,259
    Quote Originally Posted by JayBauman View Post
    Where is that dang official jaybauman emoticon???
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    -- Guy --
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Took off cover 2 days ago, clear but #s low. Used new Stanley leaf gulper that I'm not to fond of, brushed w new Whale Wall brush that im not too fond of and using my new speedstir that im VERY fond of. Added CYA, Borax, bleach. Water temp only 60. Cleaned out skimmer basket a gazillion times of oak frond things. I thought they were through falling. Oh and I cleaned out around my pump pad.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by pooldv View Post
    I've been waiting for that one for awhile myself. Although displaying it would probably get me banned....
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Changed 325 lbs of filter sand (was way beyond deep cleaning), brushed in 500+ pounds of salt, installed a timer, started installing my new SWG. I am beat.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Propbndr View Post
    Man, I bet you are! So far today, I think you win, what a day...First one's on me.
    Go ahead...post it up....and we'll see...
    Essential Links:
    DFW, TX
    24,259
    What'd you do after lunch???
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Lunch? What is that?
    Steve
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Essential Links:
  20. Back To Top    #20
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,970
    Man, woodyp is right! Its absolutely ridiculous this year! Its been years since I have seen the pollen this bad here. The stuff has buried me in it!
    Divin Dave,
