Thread: Baking Soda
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Baking Soda
    I decided to call a feed store about Sodium Bicarbonate and they carried it in 50 pound bags for $18. I'm including a snap of the ingredients all of which are safe for pool use. Cheapskate level pro...
    I split it with a neighbor so 25 pounds at $9.....
    And for fire ants around the pool.....95% Acephate.... 1 pound at $18....
    I live in the city, but the feed store was only 5 minutes out of town.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Re: Baking Soda
    That is a good price. But I have to ask why? What is the overall need for that much bicarb on hand?
    You start with a recommended TA level of 70 to 90, which is most likely similar to your fill water. You now have enough sodium bicarb on hand to raise the TA in your 13,200 gallon vinyl lined pool by 100 points.
    You will typically find that most TFP maintained vinyl pools will reach a happy medium on the TA and the Ph will raise slightly over time with use of bleach. If anything, you will most likely need to lower Ph every few weeks and take small actions to lower your TA on occasion.
    Does your pool have some issue where TA is consistently low?
    I'm not trying to be a pain here, I have 4 to 5 lbs of A&H Baking Soda that I bought 2 years ago sitting on a shelf in the basement right now, and never use it now. Yeah I used to notice the water was a little softer/silkier with bicarb additions, but as soon as I stopped doing that, my Ph swings leveled off and I stopped chasing my tail. I typically add 16 oz of MA every three weeks to keep my Ph in check at this point, and live with a TA of 90 to 100. YMMV.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Aug 2014
    Shallotte, NC
    693
    Re: Baking Soda
    Don't know about the OP, but on a fresh refill (not yet completed), Pool Math suggest I need to add 31# of Baking Soda. The OP, also, noted he had split it with his neighbor....
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Baking Soda
    Plus you can use it in your laundry....
    Orlando, FL
    690
    Re: Baking Soda
    Does a fabulous job cleaning my dishwasher every few weeks. Baking soda, table salt, and Dawn. I put it in the detergent cup and run a normal cycle. Dishwasher cleans like new. Now, for the other 4.97 lbs. Lol. Good thing is the it doesn't go bad.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    May 2012
    Cincinnati, OH
    189
    Re: Baking Soda
    ewkearns I would suggest you test your fill water for TA. An addition of 31 lbs in your new fill on a 30k gallon pool would be good if your fill water is zero TA, which highly unlikely.
    I'll also note that I did read that the OP split the original 50 lb bag it with his neighbor. The remaining 25 lbs he has will raise his 13.2k gallon pool by 100 points, as stated earlier.
    TFP practice suggests you have a reason for and a understanding about adding things to the pool.
    $10 will buy me two weeks worth of bleach. I'm just curious why I would want to have the bicarb sitting around taking up space and why have a sunk cost in something that may not be needed?
