I have High alkalinity both in the pool and source water and currently the pool TA is at 325 ppm.
I have learned that High TA can effect the chlorines ability for disinfection purposes. I have what appear to be algae showing up in the grout lines in part of the shallow end with most of the bather load,could that be a side affect of the High TA, and what would you suggest I do to eliminate that problem The FC is kept at a 3.0
