Thread: Liner Lock
    Mar 2012
    Just South of Atlanta, GA
    18
    Liner Lock
    As you may have seen my other post. I am installing a new liner in May.
    The company said I may need "Liner Locks" ... what the heck is that?
    THe did a very detailed measurement of the pool for the new liner so would I need this thing or is this a
    way of getting more cash out of me?
    16 x 36 IG Vinyl 27,000 gal, AutoPilot DG-220 SWG RC-42, Dolphin Premier bot.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Liner Lock
    Liner Lock is a strip of something that you push into the liner track. It prevents the liner from coming out of it.
    http://www.amazon.com/s?ie=UTF8&page...20Liner%20Lock
    its not a necessity unless for some reason your liner has a habit of popping out of the track.
    Divin Dave,
    Mar 2012
    18
    Re: Liner Lock
    Thanks Dave!
    The old one never came out so ...who knows.
    Re: Liner Lock
    Liner lock is a very inexpensive strip of plastic that gets wedged into the channel along with the liner to make sure the liner will not slip out of the channel. Typically you install a liner without it, and then if portions slip out they are put back in with liner lock to make sure they don't slip out again. In some cases older channels with new liners require liner lock all the way around the pool. The product it's self is very inexpensive, and the extra labor involved should be minimal.
    Mar 2012
    18
    Re: Liner Lock
    Super ! and thanks for the info, this may be a good thing to have even if I don't really need it. I found it for abaout $100 online.
