Thread: Algae in my pool
    Jul 2013
    Royse City, TX
    32
    Algae in my pool
    Hello,
    This was my first winter to have an above ground pool and with very little attention thru the winter I have a good case of algae.
    I have the Tf100 test kit.
    My ph is off the chart. Do I continue to add muratic acid until I get to the desired level before beginning to SLAM?
    Help is needed in North Texas.
    Thank you,
    Esther Williams Classic, 30' Round AGP, Hayward Pro Series Sand Filter, Pentair 340104 Dynamo 115V Single Speed
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Algae in my pool
    Short answer: yes, fix pH first.
    What are the rest of your readings like? If CYA or CH has built up to where you might want to replace some water, do that first. Otherwise, fix the pH and jugs away.
    Jul 2013
    Royse City, TX
    32
    We are moving in the right direction.... seeing some improvements!!!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Quote Originally Posted by TaraMM View Post
    great!! Get the pH in line then SLAM away.
    Support the site
