Thread: Saltwater test kit
    Feb 2014
    Upstate, NY
    390
    Saltwater test kit
    I have the TF 100 test kit now and recently changed over to a SWCG. Can I still use this kit to test the water levels ?? Thx
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: Saltwater test kit
    Yes, you still need your TF100 to test your standard chem levels, but I added a Taylor #1776 (I believe?) Salt test kit to mine too. Its a drop method to determine salt levels separate from the TF-100 kit. I started with this test kit so know nothing about the salt test strips, but others here can advise you on them. One doesn't normally need to test salt levels often.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Yes of course! It cannot test for salt though. Like skippy, I also use the 1766 kit for testing salt level.
    EDIT to Add. - the drop based test kit rocks! Its very handy.
    Quote Originally Posted by Donny View Post
    Divin Dave,
    38,532
    Me 3
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Just to clarify in case the OP does a Google search the Taylor Salt test kit is the K 1766 not K 1776.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Feb 2014
    Upstate, NY
    390
    Thank you everyone!
