Results 1 to 10 of 10
Thread: Pool opening water adjustment order
    swirlywater's Avatar
    Feb 2015
    columbia station / OH
    63
    Happy Spring everyone. I am getting a jump on opening the pool before it gets warm enough for anything to grow. I just tested my water which is probably about 1/3 from snow and rain; i have a mesh winter cover. FC=0, CC=0, PH=6, TA=20, CH=40. I used my test kit from last year, is that a problem? The water is clear with just a tiny bit of debris. What order should I add product to get the chemistry back in check? This is my first opening. What is the best products to start with? I was planning on liquid chlorine, borax, and baking soda. Oh, and I should mention the one skimmer i looked in appeared to have a little white slime in it. Any idea what that is? It is far too cold for anything to grow here in NE Ohio.
    20x40 30k gal vinyl, Inline Tri-Chlor Chlorinator, Hayward 250K btu heater, Hayward 2HP Super Pump, Hayward DE6020 Filter,
    Re: Pool opening water adjustment order
    Start by raising TA to about 60 first, then retest PH and adjust PH up to at least 7.2.
    You will need to measure your CYA level as well. Unless CYA is high enough already, raise CYA to around 30.
    If CYA is zero, start adding 2 PPM of chlorine in the early evening after the cover is off. And then switch to targeting the FC level appropriate for your CYA level 24 hours later. If CYA is 20 or higher to start, go straight to targeting the FC level appropriate for your CYA level as soon as the TA and PH are adjusted.
    Feb 2015
    63
    Thank you. What about the Calcium Hardness? I have a vinyl liner, is it even important?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Did you take those readings after the water had time to mix? Is it circulating? You might have a layer of snowmelt on top.
    Low CH is no problem with vinyl pools. You won't damage plaster. Some people have problems with foaming when CH is below 200. Wait and see. If you don;t, or of it doesn't bug you, you don't need to spend money on adding it.
    I have no idea what the slime is. Maybe pollen?
    Feb 2015
    63
    Good advice. I will get the pumps hooked up and re-test before I add anything.
    38,521
    Welcome to TFP!!!
    Has anyone warned you away from the Nature 2 minerals yet? I highly recommend you get the metal pack out and not introduce them to your water.
    Feb 2015
    63
    Yes Sir. I have read about it all week and will be starting up this year without it. It came with the pool when it was installed last year. I suspect it is the cause of a little discoloration on the fiberglass stairs. I checked them this morning, after cleaning them with a magic eraser when I closed the pool, and they are back to white.
    What about my test kit, Taylor K-2005. Is it ok to continue using it for a second season? Is there any indicator that the reagents are spoiled?
    38,521
    On Taylor's website (and somewhere on the forum) there is a description on how to know if they went bad.
    If it was truly new when you bought it and stored it well, it should be good.
    Do you have the FAS-DPD chlorine test?
    The best indication of reagents expiring is that if the organic dyes stain their plastic containers, they are bad.
    Feb 2015
    63
    Thanks for all your help. Pool opening was smooth and the water is clear. Jason, I ordered the FAS-DPD test a little bit ago and should have it this week sometime.
