Thread: Return Jets Positioning
    fatboy1271's Avatar
    Aug 2013
    West Hills, CA (Los Angeles County = no water)
    128
    In the picture I've drawn arrows as to where the three return jets are and the directions that they are sending water. The two on the right side of the image are PARAMOUNT iJETs and the one on the left, which is the most powerful, appears to be a regular elbow PVC coupler. The area at the bottom is generally at a standstill; I just happened to have skimmed the pool before taking this picture. My question is what is the best set up for my pool so that water circulates everywhere instead of just 2/3 of it? I was thinking of either flipping the elbow to point to the shallow end, but I'm not sure what that would do to the circulation at the deep end. Or replacing an iJET with a 45 elbow at the stairs and directing that to the shallow end.
    Patrick
    Gallons = 17K / IG / Fiberglass / Filter = Hayward DE-6000 / Hayward EcoStar Variable Speed / Pentair IC40 / 1976, I believe / Shape = "Kidney Bean"
    TF-100 / SpeedStir Magnetic Stirrer / Dolphin Nautilus Pool Cleaner / Wall Whale
    Re: Return Jets Positioning
    The middle jet should point just to the right of straight towards the viewer of the photo, i.e. down the length of the pool, just in front of the steps, while the jet closest to the steps should point directly at the steps. That should be enough to get it to continue along that side of the pool all the way to the far end.
    fatboy1271's Avatar
    Aug 2013
    128
    Awesome, thanks Jason!
    Patrick
