Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: What would you go back and put in if you had more money?
    Feb 2015
    Austin
    133
    I just discovered I have more money to put into this pool than I originally thought. When I signed the contract, I went through and scratched out a lot of add-ons I didn't think I'd use (LED Lights, did plaster only, auto-fill, heater, spa, standard tile/coping only, etc.)..
    If you could go back and add anything, what would you install? I don't want to regret passing on something that will be hard or impossible to put in once the pool is finished.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Re: What would you go back and put in if you had more money?
    My pool hasn't gone in yet - so no comment.
    Other than Mo Money, Mo Money, Mo Money!!!! Congrats!!!!!!!!
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Heater
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jan 2015
    Austin, TX
    1,095
    Quote Originally Posted by tedujam View Post
    The only things impossible to add later on your list are the spa/heater and auto-fill. Auto-fill in Austin costs a fortune BTW so I decided to skip on it.
    I wanted my pool to last a long time so I put a larger filter, pebble finish, and LED lights hoping to get longer times between replacement.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    I wish we had a real beach entry. There isn't enough room, so that would also mean a larger back yard
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Those beach entries are NICE!
    Mar 2013
    New Hampshire
    351
    Heater, another light and more pavers
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Jun 2013
    Erie pa
    68
    Heater
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Umbrella holders would have been really nice.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Jan 2013
    Friendswood, TX
    320
    I have a cocktail cove and table. I wish I had a return or two in that nook. Also lights in the waterfall.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Jun 2011
    Long Beach, CA
    2,781
    I wished my pool started with all these items LED lights, automation, SWG, heater, solar, a VS pump, but they can all be added on at any time with not too much difficulty if planned out right. What needs to be thought of is the equipment pad location and size. Try to keep everything spaced out and not jammed into a tight space. This will make upgrades so much easier in the future.
    Large enough filter so you only have to backwash and clean the filter once or twice a year. I haven't touched my filter in 8 months other than to release the trapped air inside it after cleaning out the pump basket.
    I would include a sewer drain line for backwashing or draining the pool.
    A must have is an easy entry and exit point, no ladders or rails needed. A beach entry or baja shelf would be nice. I have a baja shelf that is 12" deep with a 6" entry step and it is a great area for the little ones.
    My ideal pool would be long enough to include a lap lane with minimum 4' depth for flip turns. I would use the pool for exercise way more often if I had this available in my pool. As it is, I use public pools for exercise.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Beach entry would be sweet, and even though I don't think we would utilize it a lot, I kinda wish sometimes we did a spillover spa. LED Lights.
    Essential Links:
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    I would have added something to give us a bit more shade.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Jun 2011
    Carlsbad, NM
    171
    Larger spa, and one more led light. During our remodel, I tore out the autofill. I see it as something that isn't needed.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    A bigger pool!
    Divin Dave,
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    Longer and deeper. 44' long and 10' deep. Gas fire pit.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2014
    Gilbert/AZ
    27
    Enclosed (or shaded) equipment pad.
    Owner-Builder, 13,500 IG StoneScapes Mini Pebble (Aqua White), Pentair 160301 Cartridge Filter, Intellichlor IC40, Intelli pH system, Intelliflo VS pump, Startup 2/26/2015
    Apr 2015
    DeBary FL
    8
    If you backed out of an interior upgrade like pebble for quartz, you should consider adding that back....in my humble.
    Sep 2014
    North DFW
    161
    Bigger tanning ledge, more jets in the spa, and a gas firepit
    39' x 18' IG 3.5X4.5X9 34k gallon w/ raised spa, 3 stone scupers
    Jandy 60 SqFt DE, Jandy PDA PS6, Jandy JXi400 heater, Jandy 2.0 EPump w/SVRS
    A&A Manufacturing ICS w/G4 venturi heads
    2 incandescent lights in pool, 1 in spa.
  20. Back To Top    #20
    Apr 2015
    Pennsylvania
    8
    Larger deck, heater and some type of solar setup
    27 Foot diameter 52" vinyl liner pool above ground, Hayward EC50 DE Filter, BBB method.
