Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: Slamming questions.
    BrunetteNTx's Avatar
    May 2013
    Lufkin, Tx
    32
    Slamming questions.
    I will try not to make this a story.
    Pool
    Lost pool cover in Jan. Some leaves in bottom of pool.
    Have been dipping off and on for most of day. Most are in the center now.
    added 2 pds granular sanitizer that i had laying around yesterday before i found the SLAM instructions so
    know i have no idea if my PH is correct. Got up this morning i was able to at least see the brown blobs of leaves (couldn't
    see that yesterday) and
    added 2 gal of liquid chlorine kemtec brand this morning .
    Went to town could not find the FAS-dpd kit at leslies so i got the DPD kit and have tested my water
    according to the instructions. This is what i got with the test Kit
    FC 5ppm
    TC 5ppm
    if i calculate it right that would be 0 FC correct?
    CYA 35PPM
    PH has got to be above 8.0 because its color looks to be brighter then 8.0
    So i have looked at the chlorine/cya chart but i am confused. I do have a salt system but it is not plugged in right now
    as i figured it more important to get the green out of the pool first.
    So, do i need to stop and get my PH correct and then proceed with the SLAM?
    Do i follow the chlorine/cya chart for a SWG or NonSWG?
    Just a few of my million question
    well i guess my siguature didn't add so here it goes:
    East Texas
    16x48 above ground metal frame intex pool
    new 1500 filter pump
    intex salt system
    East Tx,5000 gallon,Intex 16x48 above ground metal frame pool
    Intex 14in sand filter 2150 gph
    swg by Intex (not currently hooked up)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Slamming questions.
    Welcome to TFP Brunette
    Yes, you need to adjust the pH before SLAM, but you don't have the proper kit (Chlorine kit) for doing that. They are not usually anywhere in stores.
    You need a FAS/DPD kit because what you have will not range high enough for a SLAM.
    If your test is correct and let's assume it is, you would have 5 PPM FC not 0. You might be thinking about CC (Combined Chlorine) but I don't think your kit shows CC. Does it have a test for CC or Total Chlorine, or just FC?
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    almost impossible to find FAS/ DPD in stores. Here is a link to where to get it. www.tftestkits.net. Click on the 'refills'
    you need the R0003
    R0871 and R0870
    As Patrick says, you need to get your PH down before slamming.
    As for which chart to use, - for slamming it doesnt matter. You use the column on the far right of the CHlorine / CYA chart.
    with CYA of 35, (consider it for for slam purposes) your SLAM level for chlorine is 16
    Divin Dave,
    May 2013
    Lufkin, Tx
    32
    Thanks for the reply guys
    My test kit does the following:
    free and total chlorine or bromine, ph, acid & base demand, total alkalinity, calcium hardness, cranuric acid.
    I have a r0003 in this test box but i don't have r081 or r 0870..
    And yes i mean't CC not FC (dang kid) !
    It says to get CC you have to use formula of tc-fc=cc
    after i tested the above post i added a 3rd jug of chlorine and just got back home and tested again:
    still at 5 ppm fc
    still at 5 ppm tc
    which makes CC=0
    but, my CYA has rose to 50ppm
    I guess i need to go and read up on the PH stuff again and try to figure out how much acid i need to use for my pool.
    I spend 80 bucks on this test kit today..I did not know it couldn't be bought in most store
    I bought a bottle of green algae eliminator but it says i have to get PH down to use it as well
    Last night, overnight i lost all fc..when i got up this morning and tested it was at 0!
    off to do more reading!
    and maybe get my sig to work!
    Stacey
    Oh and i should just let the pool go back to 0 fc to fix the ph correct?
    Forgot to ask this
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Stacey
    Do not let the FC go to 0. You can add Muriatic acid to lower the Ph as long as FC is lower than 10.
    Do you know how to use Pool Math? Here is a link to it. Ask if you need to help figuring it out.
    http://www.troublefreepool.com/calc.html
    And yes, TC-FC=CC.
    The CYA test is tricky. Available light has a lot to do with teh accuracy. Dont worry though, we all go through that learning curve. I would recommend to measure CYA again.
    Go outside on sunny day and mix the CYA mix. Turn your back to the sun, and hold the test tube at waist level and squirt the mixture into the tube until the black dot disappears.
    you can use the same mixture to repeat the test, just pout it back in the bottle and repeat a few times ...
    I would not recommend using the algae eliminator. It very likely contains copper which can stain your pool.
    Chlorine will kill it faster than the copper based products will.
    Your description of the test kit you have sounds like a Taylor K2005. Is it?
    To measure FC higher than 5, you need the R0870 and the R0871. Page 2 of that test kit website has a combination pack that will save you a couple of dollars. If you are going to SLAM, you have got to be able to measure high levels of Chlorine.
    Divin Dave,
    May 2013
    Lufkin, Tx
    32
    Good Morning all,
    First thing first...I went to website and found this test kit for 26$ it has a powder. I assume that is ok and here is the discription
    FAS/DPD Chlorine & CC's test
    2 oz R-0871 Reagent
    10 g R-0870 DPD Powder
    40 ml cylinder
    Scoop
    .75 oz R-0003 Reagent
    This FAS/DPD Test will test Free Chlorine up to 50+ppm with an accuracy of .5ppm. (.2ppm if you really need to be precise) Additionally, it contains the R-0003 reagent so you can test for combined chloramines.
    I believe this is what i need to order Please correct me if i am wrong.
    Tested again this morning. I did the entire kit this morning and here are my readings:
    More then 5ppm fc (have no clue the actually number cause dummy me didn't buy the above mentioned kit)
    more than 5ppm tc ^^^^^
    makes that 0 cc ...sigh ^^^again....
    bromide 10 ppm
    cya 45 I did as you suggested about testing at waist level..tested several time also!
    It took me 30 drops to get to red on ALK so that makes it 300 ppm
    Cal hardness took 30 drops as well to get to a shade of blue so thats 300 ppm
    And lastly the Ph..It is going to be above a 8.0 so i did the acid demand test it took 5 drops to get it to the correct level.
    Checked the book that come with the kit and it stated 5 drops at 5000 gallon pool would =1.43 pt of muriatic acid.
    Does this seem about right?
    My kit appears to be a k2005
    Pool is a nice shade of blue white and green.
    About to throw in 2 more jugs chlorinating liquid
    Let me know if that is the correct kit i need i want to order it asap!
    I am on vacation and want to get this pool finished before i go back to work LOL
    Thanks for all your help!
    Stacey
    East Tx
    5000 gallon
    intex 16x48 above ground metal pool
    new filter pump intex 1500gpm
    swg by intex (not currently hooked up)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi again,
    The FAS/DPD kit is the right one. Get it.
    I would recommend to test TA again to make sure there isnt a mistake. TA of 300 is way high. What TA does is help buffer the PH rise. Until you get the TA down, you can expect to have to lower Ph every day.
    Good deal on measuring the CYA! Sounds to me like its 45! Thats good. Dont do anything more with it. With a CYA of 45, you should aim for FC of 6 and never let it get below 4 for regular maintenance. For SLAM, you FC level is 20.
    There is no reason to test for Bromide. That is used in Hot Tubs.
    For Ph, I dont know if 1.43 pints is right or not but its close! You dont mention exactlhy the PH level you are aiming for. What target you aim for is part of the equation to determine how much MA to add. I used pool math and plugged on your pool volume and used a NOW ph of 8.2 (the highest you can test for) and a TARGET Ph of 7.4 with TA at 300. Pool Math says to add 28 oz. of Muriatic. (FWIW, I trust pool math more than I trust my mother!).
    CH isnt really of any consequence in a vinyl liner pool unless it gets way high, like +500 or more. No need to test it unless you just want to.
    The Taylor K2005 is a great kit, just missing the FAS DPD. It will serve you well!
    Hope this helps,
    Quote Originally Posted by BrunetteNTx View Post
    Good Morning all,
    2 oz R-0871 Reagent
    40 ml cylinder
    Scoop
    bromide 10 ppm
    Stacey
    East Tx
    5000 gallon
    Divin Dave,
    May 2013
    Lufkin, Tx
    32
    Hello all.
    Tested again today. Did not do much of anything with it yesterday but add 1 jug of chlorine. It was pouring down rain and i have been sick for the last 3 days just getting progressively worse. Probably all this algae in pool LOL silly pool! I MUST be better before Friday I am going to my first NASCAR race!
    Cleaned pump first thing this morning and must say there is a lot of very white matter floating around in there! Flushed it out..back to town for more chlorine.
    Continued pulling as many leaves out of the middle as possible till i lost my pool brush ..yes, in the white abyss... Not feeling to confortable climbing off in there. But still cant see all we way down to get it out...sobs
    So, after the two cups (there about) of muratic acid and a day of rain i have a PH of 7.4. I tested in the day after i put it in and it had not dropped any that i could tell so don't know what happened with a delayed reading.
    cya is between 50/60
    5 still on TC (kit is ordered waiting..)
    3 of FC which is a change
    so that makes my CC a 2
    Alk 225 ppm..
    7.4 ph
    added 2 bags of chlorine that i got a leslie's ..
    Im really just waiting on that test kit ...
    So at what point does the SWG get to turn on?
    Thanks
    Stacey
    East Tx
    5000 gallon
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Later when you are done with the SLAM.
    Once you get the kit, you'll have to hit it hard and stay after it to get this resolved, but in that size pool it's easier in terms of hauling and adding less bleach than a big pool.
    Essential Links:
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Be careful with those bags from leslie's, they probably have cya in them. You shouldn't add any cya until you're done with the SLAM. The higher the cya, the more bleach you're gonna need!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    May 2013
    Lufkin, Tx
    32
    Thanks everyone!
    Filter was really bad this morning. Might have to do a replace in a day or two.
    I went out and looked at my bags from Leslie's and they say:
    power powder plus step 3
    calcium hypochlorite 73%
    other ingredients 27%
    max 70 % chlorine
    I tested my cya it was between 50/60 yesterday and now i am at a 40
    5 ppm fc (and it truly will be a 5 the color matched perfectly)
    5 ppm tc
    0 cc
    ph 8.0 added another 2 1/4 cups of Muratic acid
    tested the ch this morning it was 175 ppm (before i added the acid)
    Not sure if i should add the leslie bag they told me it had a lot of chlorine in them so that is why i got a box of it!
    Bleach or bag?
    still waiting on the test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Without knowing your True FC, I wont suggest you use the bags. It really will be better to wait until you get your kit to see what you have in the pool. CH is not so important in your vinyl pool, but it's best to wait, as hard as that is. Once you have good test numbers, we can advise you properly. When did you order the kit?
    Essential Links:
    May 2013
    Lufkin, Tx
    32
    i ordered kit on friday..
    (first time trying to add a picture of my still green pool)
    I am thinking seriously of draining some water out. I really need to get the brush out of the bottom and i can't see to get it out...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It would not be a bad idea at all. You should have the kit today, or tomorrow at latest.
    Essential Links:
    May 2013
    Lufkin, Tx
    32
    Ok, about half of the 5000 gal of water is gone! Yep, drained some off.. Found the pool brush! Finally! Fixed it so it wouldn't fall off (i'm such a rookie)
    sweep, sweep, sweep..can see no more brown blobs in the bottom...
    as of 2pm still no test kit.
    Ok, so now what?
    So i first am thinking..Fill the pool back up...lol
    But seriously thinking about taking more out.
    My logical mind says get rid of more water and you will get rid of your problem.
    But since both my minds can't make up one mind i will ask ya'll..
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I did what you are doing now in about the same size pool. To this day I wonder why I didn't just drain and refill.
    You may still need to do a little SLAM if you drain/re-fill completely, but it will be relatively short and easy. Hence, the "Little SLAM". Yes, it would help, without question.
    Essential Links:
    May 2013
    Lufkin, Tx
    32
    ok just seriously pulled the plug on this thang..
    I am out of time Got a Nascar race in 4 days and i just want to get this **** done and over with LOL
    No test kit in the mail today... ;(
    Going to get her seriously LOW and then fill her back up.
    Going to get a lot of bleach...again!
    Going to do this if it kills me..
    Going to need you folks to tell me where to go next!
    Stacey
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Don't put anything in it but water. Check back when it's full.
    Essential Links:
    May 2013
    Lufkin, Tx
    32
    will do
  20. Back To Top    #20
    May 2013
    Lufkin, Tx
    32
    So i am just now starting to add water...Here is what she looks like now
    Im really fighting the urge to add a couple of bottles of bleach while there is not so much water but i will do as i was told
    Still finding a lot of little brown triangle thingies in there..I am sweeping and trying to get it all out.
    About to go check mail for test kit..
