Results 1 to 12 of 12
Thread: Which brand of telescoping poles do you recommend?
    Jul 2014
    Berks County, PA
    206
    Hi,
    I came across what looks to be a really good pole....made by Skimlite....http://www.poolweb.com/Shop-On-Line/...ELESCOPIC-POLE, and then there are some made by Poolmaster (which is the brand my supply store carries). I'm thinking that the Skimlite is probably the better product, but is considerably more expensive. http://www.poolmaster.com/product/po...e-locking-cam/
    Any recommendation either way?
    Keith
    12,000 gal. Anthony IG pool; 3 ft. shallow end to 6 ft. deep end; Built 1989; Renovated July 2014 using a 10-part unexposed quartz plaster aggregate of 3 S-grade Blue, 3 S-grade Gray, 2 T-grade Blue, 2 T-grade Gray; Apollo VA-52 DE Filter; Hayward SP-2607X10 Super Pump 1-HP Single Speed; Jandy AE-Ti Heat Pump; Taylor K-2006 Test Kit
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Which brand of telescoping poles do you recommend?
    Hi Keith,
    Have you been to a local Home Depot/Lowes? I think they're much cheaper ($25). http://www.homedepot.com/p/Unbranded...3796253?<br />
    Sorry I wouldn't spend $90 bucks on a pool pole. The cheap ones ($25) are pretty durable and light. You can even get the replacement collar if needed.
    Feb 2014
    Upstate, NY
    390
    I agree with Bob. 90 bucks for a pool pole is very steep. Having said that, it did look like a quality piece. The Home Depot pole suits me fine.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have a Home Depot pole too. One thing about telescoping poles. The longer they are, which seems like it might be handy... the heavier they are. You'll surprised how much a light pool pole ways after you have been wagging it around for a while scooping out leaves.
    Divin Dave,
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You can get that Skimlite for closer to $50
    Jul 2014
    Berks County, PA
    206
    Thanks for the replies. One thing I didn't think about is what someone said in another forum- which is that the sun will destroy the plastic components in an outside lock. I know they make poles with elliptical (inside) locking mechanisms also - as long as it holds up. This whole thing is a bit ridiculous really - I HAVE a pole - a 16' that I've used for the past 25 years - solid as a rock - but unfortunately I just got a new fence around the pool and with the way the sections angle, I no longer have a 16' run where the pole can fit against!! That's the only reason why I'm thinking of getting a telescopic - I have about 8-10' straight run of fencing to put the pole against. I'd much rather use what I have, but I surely don't want to be carrying it back and forth to my storage garage before and after I use it each time!
    Apr 2011
    Murrieta, CA
    2,360
    Hmmm. What about mounting it Vertical or at an angle.
    Jul 2014
    Berks County, PA
    206
    Vertical mounting might look a bit odd....this 16' pole sticking up in the air. Thanks for the suggestion though...worth considering all options. Actually, I've often thought that telescoping might be nicer. I was always banging into the old fence with mine - being so long, and now with a new aluminum fence the last thing I'd want to do is be whacking into it and scratching it all up with the end of my long pole.
    What kind of locking mechanism does the Home Depot pole have? Elliptical or outside?
    Apr 2011
    Murrieta, CA
    2,360
    Outside. I've had one for 4 years in the sun, still works good as new.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Quote Originally Posted by bobodaclown View Post
    Any idea where to get the replacement collar?
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by three4rd View Post
    Vertical mounting might look a bit odd....this 16' pole sticking up in the air....
    Goofy 'ol me, I like the vertical idea. Stick a flag or a pennant on the end when ya put it away. I'd never get away with it, though. DW would eventually notice....
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Quote Originally Posted by sargent View Post
    I found this site:
    http://www.poolmaster.com/?s=cam&post_type=product
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
