Results 1 to 10 of 10
Thread: New AG pool plumbing and equipment
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    So, I love this site and have been reading and rereading for almost 2 years I know I have alot of questions, just trying to get it right the first time..
    I need some help with plumbing and equipment, below is the equipment I am going to be installing. I want to plumb this as if it was inground and use 2 inch pipe for everything. All pipe will be buried between pool and pad and solar. Is there aditional equipment I need?
    I plan to use the union ball valve between each piece of equipment, that way if I need to change out anything I can shut off the flow and replace.
    How do I go from 1.5" inch skimmer designed for flex hose to 2 inch pipe then back to 1.5" into the pump? (is it better to just use 1.5" pipe?)
    Whats the best way to then go 1.5" from pump to 2 inch filter? is it best to use 1.5 to 2 inch Jandy valve in between pump and filter?
    Stay 2 inch from filter to 3 way jandy valve for solar and salt system.
    2 inch to solar with ball valve and union to set flow.
    2 inch to salt system
    2 inch return to pool from salt system ( how do I go from 2" back down to 1.5" return through wall)
    seperate 2 inch return from solar, what is the best way to install this pipe? ( http://www.h2otsun.com/pools/ )
    Should I have 2 skimmers and 3 returns or 1 skimmer and 2 returns?
    Thank you all for any assistance with this... Can you say "steap learning curve" I can
    ELIXIR 27X52" POOL, 7.5 Resin Top Ledge, 6 Uprights, 27' round x 52 deep 18,000 Gallon
    Waterway 2 speed, 2 HP, (1.5 inch connections)
    Pentair Clean and Clear 320 sq. ft. Cartridge Pool Filter ( 2 inch connections )
    CircuPool SJ45 Salt System ( 2 inch connections )
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER Sunheater Solar Pool Heater
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER True Union PVC Compact Ball Valve
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER PVC Pipe Fitting, Union
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER PVC Swing (No Spring) Check Valve
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER 3 way Jandy Valve
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: New AG pool plumbing and equipment
    Quote Originally Posted by cowboycasey View Post
    I will warn you. Ball valves love to seize up. Jandy valves FTW
    The more junctions, the more potential leak locations... I'm 93% sure there are PVC bits that convert 1.5'' to 2'' and back...
    example: http://www.amazon.com/Sch-PVC-DWV-Re.../dp/B000BPG5QM
    I have no solid opinion on the wise/unwise nature of such a thing. Others will be here shortly.
    I love me some Jandy valves.
    ELIXIR 27X52" POOL, 7.5” Resin Top Ledge, 6” Uprights, 27' round x 52” deep 18,000 Gallon
    I'd eliminate the ball valves from your setup. I'd Use Jandy valves to separate your pool from your equipment pad....if you need to R&R any piece of equipment. I'd also use the twist on junctions only where necessary. They leak 330x more frequently than glued junctions.
    I really like the Jandy check valves too. (I think they are jandy... they are rebuildable like the jandy valves)
    my .02
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    38,456
    You just need to use a 1.5"/2" adapter to switch between the sizes. A trip to the hardware store and playing with all the fittings should clear things up. No issues with dropping the size when you need to.
    Usually one skimmer is plenty, if it is on the downwind side of the pool. A second one can be helpful if you winds shift. For the returns, I am not sure it would make a hole lot of difference between 2 or 3 jets in a circular pool.
    Jul 2013
    Fletcher, OK
    3,353
    Ok, I made this plumbing diagram from the recommendations.. How does this look? Would anyone change anything?
    Attached Files Attached Files
    38,456
    If there is one thing I am sure of, it is that I will not open a zip file from someone I don't know
    Why not just post the picture or attach the regular file?
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    Jul 2013
    Fletcher, OK
    3,353
    LOL, should have thought of that... size limit for attaching pdf and jpg was too low... Let me see if I can get it a differant way.. wait 1
    Got it...
    38,456
    That is entirely an excessive number of unions. Why do you think you need so many?
    At most I would think you would need 1 union in front of the pump, 1 between the pump and filter, 1 after the filter (and the SWG has unions, so probably do not need this one).
    You should put the SWG right after the filter before the 3-way so that you get FC to the pool when you are running the solar panels too.
    Jul 2013
    Fletcher, OK
    3,353
    I tend to overkill things
    The SJ 45 SWG does not have any unions, just a clear case, so I really want 2 on there just in case.. Also, I read to have the SWG the last thing in the pipe so gas does not build up and blow the pool up.. that would suck..
    There are 2 unions on the pump and 2 on the filter already, So I am really only adding the 2 before and after the jandy valves, do you think I should just not use them?
    Thanks for the help
    Casey
    38,456
    Well, unions are one place where leaks can easily develop so I would not recommend so many.
    I now see that SWG design, still not sure I see the need for unions on both sides.
    OH!!! yeah I was not think regarding the SWG and the solar. Usually the solar is plumbed before the SWG and goes to the pool at the same return jet ... yours a little different. I hope your SWG will have enough flow when the solar is running.
    There is no reason to add unions before and after the Jandy valves ... I don't think you need any that are not already part of the pump and filter. They are easy to add in the future if you do happen to need one.
    Jul 2013
    Fletcher, OK
    3,353
    Jason,
    Thanks for the help, wish me luck..
    Untill the next question
    Casey
