Thread: above ground opening
    May 2014
    Gaffney, SC
    16
    Thinking about opening in the next week or so in upstate South Carolina. Checked under the winter cover and the water looks crystal clear with no debris.
    Here are my levels:
    FC: 9.5
    CC: 0
    CYA: 40
    PH: 7.8
    TA: 80
    The water level is still 6 inches below the return. Since all my levels look so good will I still need to SLAM it?, or do anything special?
    Thanks for your help
    13.5 k gallon, AG Swim n' Play Inc. Islamorda 24 ft. round , Pentair Dynamo 1.5 HP Pump, Pentair Sand Dollar SD40 sand filter 40GPM.
    Install 5/20/14
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,570
    Re: above ground opening
    Sure doesn't look like it.
    38,251
    Looks like you are going to have an EASY opening this year.
    Just be sure to get it going before the ware warms up too much.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Indeed it does! That's normal for TFPC though, congrats!
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Sounds like a successful closing/opening! Well done! But you peaked, so I think that means the cake will fall...or am I confused?
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    May 2014
    Gaffney, SC
    16
    THANKS SO MUCH EVERYBODY.
    Glad I listened to y'all and not the pool store man!!
    Install 5/20/14
