Results 1 to 19 of 19
Thread: Is this okay?
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Is this okay?
    My pool was installed last year and being a virgin pool owner, I really didn't know what to look for while the installation happened. I was planning on opening the sand filter to do a hose clean before the season and saw this...
    It looks like they didn't use the right connections...shouldn't it be able to be unscrewed for maintenance?
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Is this okay?
    you are correct, there should be a screw on collar that attaches two premade parts together...0-ring sealed vs the silicone seal we see there. I'll try to find a pic.
    there's pics of them here....more or less...mine screw onto those threads on the valve body itself. some other valve bodies don't have threads, that's when you see the mid pipe fittings.
    http://www.inyopools.com/HowToPage/h...nd_filter.aspx
    the way they did yours may not be "wrong", but it is less than convenient.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Re: Is this okay?
    That is the normal way those connections are made. However, they did not provide you with separate unions, which are required to remove the multi-port valve. Unfortunately, leaving off the unions is quite common.
    By the by, those are screwed in connections, they just used the inside threads, rather than the outside threads. But that doesn't help you because the way the plumbing works plumbing prevents you from unscrewing the connections regardless of which set of threads was used.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Is this okay?
    Unfortunately, that is not an unusual practice. Lots of folks have to cut the piping to be able to remove the multi-port valve. I can't see from your picture, but there is likely enough straight pipe somewhere near the valve to be able to cut it and then install a threaded union. It is relatively simple and the unions are fairly cheap and readily available at the big box stores.
    Oops, Jason beat me to it. I had to add unions on mine to deep clean the sand. Adding the unions took less than a half hour and finished curing while I cleaned the sand.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Is this okay?
    Thanks everyone I thought it looked wrong. I bet they do it like that so owners are inclined to call them to service it when the filter needs to be cleaned.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Is this okay?
    Perhaps, but who knows!? Frustrating at best. Whoever did that....
    Essential Links:
    38,539
    Re: Is this okay?
    The use of silicone in this manner baffles me
    Re: Is this okay?
    I've seen that before. They used the silicone as a thread sealant, presumably because they happened to have some and didn't happen to have the correct thread sealant, or didn't know any better.
    38,539
    Re: Is this okay?
    Oh sure, I suppose it can work. But not the right tool for the job. I hate silicone since you can never ever remove it all.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Re: Is this okay?
    My Sand Filter Multi-Port is installed the same way. Although I can dis-assemble the Multi-Port from the Top, if an issue occurs with the valve body, I will need a hack saw
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Orlando, FL
    690
    Re: Is this okay?
    Mine is like that too. And basically what Elwood58 said.
    I knew it was not right the minute I saw it but the guy was definitely using what he had available AND he was not really prepared to deal with an Intex filter. Fortunately, I was able to unscrew the top to lube the gasket. When I need to replace the filter, I will definitely be required to do some serious re-plumbing but it's ok because I cannot imagine needing to mess with the filter for several years. When I do re-plumb, someone on the thread will have done it and I will just use their notes
    One question. Does this approach ruin the threads on the filter? Once you cut the pipe, how do you get the coupler off the filter? Is it as simple as using a pipe wrench?
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    38,539
    Re: Is this okay?
    Quote Originally Posted by f3justusc View Post
    If it was just teflon paste/tape, then you would just use a wrench to unscrew it. But, the silicone sticks to both surfaces, if it is all up between all the threads, I think it might be pretty hard to break loose ... and you will never get it all out of the threads ... and the bits and pieces left in the threads might make it difficult to reseal ... and new silicone will not stick to old silicone ...
    Re: Is this okay?
    I would say, very difficult, but not impossible, to remove.
    Orlando, FL
    690
    Re: Is this okay?
    I am compelled to add a picture to this thread. I am so excited to know that I am not alone in this. I have been too ashamed to share many photos for this reason.
    Thanks for the responses. That is exactly what I thought.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Is this okay?
    Haha, at least you can unscrew yours....
    Orlando, FL
    690
    Re: Is this okay?
    I don't think I can though. You can't see the silicone.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Is this okay?
    The pool was installed less than a year ago, do you think I can go after the installer to correct this? This just seems really shoddy.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Is this okay?
    No need for plumbing shame around here!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Is this okay?
    Quote Originally Posted by Defgufman View Post
    They will most likely tell you that is the correct way to connect the filter, they have always done it that way, yada, yada, yada. I'm sure they will be happy to install unions for you for a fee, all the while telling you that you don't really need them.
    Love TFP? Become a
    TFP Supporter!
