Results 1 to 11 of 11
Thread: Help me with this algae!!!!!
    Apr 2014
    Texas
    11
    Have been dealing with this since last year. I have a dark green algae that grows at the water line, but only on the mortar between my stones. I use the trouble free method for maintaining my pool with liquid chlorine, and I am about to switch to salt but I would like to get this problem solved before I do the switch. Here are my last test results:
    FC 8.5 I raise this to 10 when I add chlorine.
    CC 0
    CH 450
    TA 90
    CYA 90
    PH 7.8
    I've attached pics of the algae. Thanks in advance.
    21'6" x 38' Inground pool with Onyx pebble tec, Oklahoma flag stone coping with natural moss rock, Hayward DE6020 filter, Hayward Tristar SP3215X202 pump, Hayward Booster pump Model 6060, Ozone Joes OJ-45LR, Intermatic PE653RC. Pool completed in April 2014.
    S1ngram's Avatar
    Jun 2014
    Chrisman, Illinois (East Central Illinois)
    304
    Re: Help me with this algae!!!!!
    I'm just wondering. Does the water ever go as high on the rock as the algae grows? It looks pretty dry where the algae is growing in the top picture. Maybe the mortar is porous enough that it stays wet enough to grow algae? Is that what's going on?
    Not having done this for long, I do know that the algae needs to be in contact with the SLAM level water for it to be killed by the chlorine. Have you tried a bleach/water solution and an scrub brush yet? I had another idea, in the event that your water line isn't usually that high...what if you SLAMMED the pool and draped an old towel over the algae and into the pool water. The towel would wick the chlorinated water right to the area that needed it. You may need to cover the towel with plastic if it dries out quickly.
    27' round Seaspray Evolution, AG, 17,100 gallons, Pump: Hayward Power-Flo Matrix Dual Speed 1.5 hp, Filter: Hayward Pro Series High Rate Sand Filter, June 18, 2014, Kreepy Krauley Lil Shark, TF-100 test kit, Intex Krystal Clear Saltwater System
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome Bryantom,
    I hate giving bad news on my first post to anyone, but I'll give it to you straight. If that area is intermittently wet and dry, there is nothing you can do with your pool chemistry to stop it. If it does not remain submerged, you will have to address it manually.
    As for your pool, your Cya is up there a little too high, so I would caution you to work it down, and refrain from using stabilized Chlorine products at this time.
    Essential Links:
    30,432
    Bryantom,
    Get a spray bottle and fill it with Clorox. Spray a light coating of Clorox on the algae/moss. After 24 hours, use a brush so you can get in there and remove any residue.
    You may need to repeat this but catch it a little earlier next time and it will simply disappear in a few hours.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I agree with the Clorox in a spray bottle solution. I have a couple of small spots in the upper part of my skimmer throat that get the same way. Clorox cleans it up pretty good.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I agree completely this is the best answer. My apologies for not being more informative about how to do it. This will work perfectly.
    Essential Links:
    Apr 2014
    Texas
    11
    Great thanks for the help I will invest in a good spray bottle and go that route. Do I need to dilute the clorox or just spray it full strength?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Hi Barandon,
    you can go full threngh if you want to. No harm. I believe however that 50/50 will be more than adequate though. Squirt a little and brush, then squirt a little more to get it all.
    Quote Originally Posted by Bryantom View Post
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Divin Dave View Post
    Hi Barandon,
    Agreed, 50/50 will nuke it.
    Essential Links:
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    50/50 and a small pump-type chemical sprayer would be best. Something chemical resistant. Give the areas a shot probably once a week.
    A household spray bottle won't last long with concentrated bleach going through it.
    Isolated Spa - 345 Gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I would try it before I spent the money on a sprayer.
    Essential Links:
