Results 1 to 10 of 10
Thread: Aquabot pool rover s2-50
    Mar 2015
    Baton Rouge, Louisiana
    92
    I am considering getting this guy for leaf duty for my first year of pool ownership. We are closing on a house in a couple weeks with a swamp, and I really want to get a Z5 or M5 but I think I will start out with something a little more budget friendly to start.
    Opinions? I am picking the 50 for the 50ft cord, I wold rather a 60ft cord or longer, but 50 should do, I have lots of outlets to utilize.
    Orlando, FL
    690
    Re: Aquabot pool rover s2-50
    I have a similar robot made by Aqua Products. It does a fantastic job. However, I would not expect it to clean a swamp before I cleaned out as much debris as possible. The bag on the robot is small and you would have to take it or and clean the bag often. Once the debis has been removed with a leaf rake, the robot will be great at maintaining.
    Also, you can search the forum for robots and find conversations about many brands. I did not realize how many there are until after I purchased mine. An EBay search will also provide a good list of the brands and some are relatively inexpensive.
    I do not know about the robot you are considering but mine does not do walls, at all. This does not bother me but it may be something for you to think about.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Mar 2015
    92
    I want the robot mostly for leaves, I plan on cleaning the swamp with a trash pump to start...
    Orlando, FL
    690
    Gotcha. It does pick up the big leaves that are on the bottom but I have not tested it on a large amount. I cleaned them out with a leaf rake long before I bought the robot.
    Mar 2015
    92
    Neighbors have two gorgeous live oaks, those come with leaves. Leaves are small but plentiful. Just one angle of attack.
    Orlando, FL
    690
    When I had an Intex pool, leaves stayed in it. The Sharkline, not so much. I don't know why but I like it.
    Mar 2015
    92
    I think it is a good starter for sub $400. I will get a big boy next year
    Orlando, FL
    690
    The way mine is working, I do not think that I will ever but anything bigger. I am glad I started small.
    Mar 2015
    92
    Good to hear
    rajung's Avatar
    Mar 2015
    Iowa
    187
    I have had mine for 2 years,I use it in combination with my poolblaster max.
    Both still work against some bad reviews, especially on the poolblaster.
    What you have to do is open them up and lay them on they're sides to dry out.I have read many bad reviews saying some of these cleaners fail within a year.
    All about corrosion!
    I think some people pull them out of the water and and forget about them until needed again.
    The Aquabot, at least for me always seems to find the far end of the pool, from the end where it is plugged in and stays in that area.Especially if there is a strong breeze forcing the top layer of water in one direction.So I have to reposition after a hour.Make sure to reposition front wheels every so often, most of the direction these things decide to go in depend on the bouncing off side wall and puts a slight spin on them to head a different way.
    The elastic on the bags will fail after the first year.Stay stretched out and not seal.
    Get 2 releasable zip ties, same as comes with the main cable and use them to attach bags to the ports in unit.Will not do side walls, doesn't climb, does a somewhat ok job of cove area.2 hr run time for large pool setting.
    Make sure to use handle on unit to pull out of water after pulling to edge with cord, fairly heavy full of water.
    I totally hate to use the long hose and vacuum bottom of pool so I use these a little more often.
    I suppose tomorrow with all this said both units will fail.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
