Thread: confusion on FC level
    rajung's Avatar
    Mar 2015
    Iowa
    185
    Last year I had a liner replaced due to seam failure after 1.5years old. 3 ft long seam separation.
    Doughboy said it was due to too high chlorine level.
    There was also bleaching around return fitting.
    Was using Biogaurd silk sticks, 2 per week as instructed by pool vendor.CYA was around 90 and FC level maintained @ 9ppm
    Doughboy says FC should only be 1-3ppm and only did a partial refund.
    I dumped the silk stick stuff last year and everything the pool store gave me with the pool purchase.
    Been using 12% chlorine-borax and other store items.
    Checked my fill water before re filling a few days ago, as usual the TA is 380ppm, city water.
    Currently the PH is 7.4 and CYA is 50ppm and TA is 180ppm.
    Once I get the FC back to normal levels after season opening shock, I assume my CYA will still be at 50ppm so I will have to maintain a FC level of 6ppm. as per chart.
    Am I going to go through the same problems since its over 3ppm since I should be at 6ppm?
    I could dump some water and refill but then I will be raising the TA and do the M. acid stuff all over again as last year.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    Re: confusion on FC level
    Having the FC level be too high does not cause seam failure, it just doesn't. Having FC be above 3 is only an issue with them honoring the warranty.
    So they are giving you a choice, you can have FC above 3 and warranty issues, or you can have algae.
    rajung's Avatar
    Mar 2015
    Iowa
    185
    never had algae.
    And the lifetime seam warranty really PM off.
    took 4 months to get back to me and inform that the liner had a major seam damage due to too high chlorine.here is a copy
    I trust you are finding opportunity to enjoy your pool this summer in spite of the cooler temperatures. I’m writing to let you know that although we are honoring the warranty discount you were given on your liner, Doughboy has denied the claim internally. This has no affect on our transaction with you as I’m choosing to maintain our position.
    The reason for their denial is that the liner has evidence of over-chlorination. Oils inherent to the vinyl are pulled from the material when over-chlorination is present. What remains is a brittle material that in this case cracked at the seam. A warranty liner replacement defective from manufacture would actually separate at the seam.
    I write this to encourage you in proper maintenance of your pool. We suggest you maintain chlorine levels of 1-3 ppm and immediately brush up any powder residue after shocking your pool. This will help maintain the color and the life of your liner.
    Please note that any claims in the future which are indicative of over-chlorination will not be honored by Doughboy or by ####. I trust you will understand this position and please let me know if you have any questions.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    That is ridiculous. I would go after the installer for the money.......
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
