Thread: Pool Cleaner Suggestions.
    Feb 2015
    Red Deer, Alberta
    89
    So I have a vacuum that does me no good... It's el-cheap-o, the pad for the skimmer it game with doesn't even line up with my hole, in order to vacuum, and doesn't have enough suck to pull out of the cracks! right now I need to literally dive in myself with the end of the hose and clean my pool, done with it I say!
    I don't need anything fancy, don't need electronics or buttons, I'm really just looking for something I can throw in my pool every time I'm done swimming and it will clean the bottom/thecracks/the walls ect by itself.
    What would ya'll recommend??
    18.2K Gallon , IG(In Door) , Vinyl , 300lb Sand Filter, Waterway PF-40-2N22M Pump, Emerson R63MWENA-4727 Motor.
    Mar 2015
    Baton Rouge, Louisiana
    19
    Re: Pool Cleaner Suggestions.
    I have the kreepy krauly and love it. I would recommend getting the "twister" that made it work perfectly.
    44,000 gallon IG vinyl liner pool. 1.5 hp single speed motor on E Z flow pump/sand filter. Unknown age of pool, Kreepy krauly vacuum, Taylor K-2006 Test Kit.
