Results 1 to 11 of 11
Thread: Pool Store Advice
    Nov 2011
    Southern Nevada
    14
    Question Pool Store Advice
    Did a straight-up drain and refill this week, no acid wash. The pool store guy actually talked me out of getting CYA, walked out with liquid chlorine and MA only. He said that since we didn't acid wash, the CYA is sticking to the walls, pipes, filter, etc and I should be fine. I've never read anything like that on the forum. Have you ever heard of this?
    First time pool owner. Fired pool guy in mid 2014. Purchased home w/ plaster 14,500 gal 16x32 inground + spa, all newer Pentair equipment.
    Test kit: Taylor K-2006 Pump: Intelliflo variable drive # 011018 4x160 Filter: Triton Fiberglass Sand Heater: MasterTemp
    38,305
    Re: Pool Store Advice
    A typical pool store employee ... he has no idea what he is talking about. Go to Walmart and buy some CYA.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    well,
    if you pour the CYA directly into the skimmer, something like that might have the smallest of chance of happening. I know for a fact pouring directly in the skimmer can clog the filter and become a mess because it just dissolves so slowly. Ive never actually heard of it sticking to the sides of the pipes and walls though. That seems kind of a far fetched tale to me.
    But pouring it into the skimmer is not the proper way to add CYA.
    The proper way is to put it in a old sock and toss it in the skimmer to dissolve. Give it a squeeze now and then to help it along.
    Repeat as necessary until all you need is added.
    Divin Dave,
    38,305
    Of course you could always fill up the pool and then run a test on the water if you do not believe us ... you have one of the recommended test kits already.
    For giggles (because that is all it is worth), you could take your new water in and have them test for CYA ... then ask him to explain why it is 0 when he said it would have stuck around.
    Nov 2011
    Southern Nevada
    14
    Thanks guys, I should have bought it while I was there. First time I was ever talked out of buying something!
    Nov 2011
    Southern Nevada
    14
    Hmmm...not a bad idea lol! I have to go back in a few days to get some liquid Cl they have on sale, I will do exactly as you recommend and see what they say.
    38,305
    You need to get that CYA in the pool pretty quickly or your FC will not make it through the afternoon.
    Nov 2011
    Southern Nevada
    14
    I experienced exactly that. I just ran to Lowe's for CYA and getting it in pronto. Thanks for the help guys!
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Quote Originally Posted by Divin Dave View Post
    ...But pouring it into the skimmer is not the proper way to add CYA.
    Interesting. When we had our pool installed in 2004 we were told to sprinkle CYA in the skimmer (should look like a snow flurry, NOT just dumped in). After 10 years I've never had a problem using this method. The filter pressure doesn't even increase, even when adding enough CYA to go from 0 to 80ppm.
    I suppose the sock method is preferred to be on the safe side for those inclined to just want to dump it in?
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    38,305
    That and then you know when it is dissolved. The flow rate in the filter is a lot slower so it may take longer to dissolve, and you are forced into not cleaning your filter for awhile so you don't lose some that is not dissolved yet.
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Good points.
    I usually only have to backwash once during the season (some seasons I've gone the entire season without needing to backwash), so loss of CYA from backwashing hasn't been a problem. Btw, I noticed from your signature we have the same filter.
