Results 1 to 9 of 9
Thread: Placing my 10' round intex metal frame pool on a concrete slab?
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    I need some advice, I put my pool last year on my old spa concrete slab. I bought a white ground cover that seemed to act like a padding. I cant find that pad anymore, would a heavy duty tarp work just as well? I dont want to spend an arm and a leg on the Gorilla pad.
    1200gal intex 10' x 30" round metal frame vinyl above ground pool, intex swg with 12"sand filter, tf-100 test kit
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    Re: Placing my 10' round intex metal frame pool on a concrete slab?
    I guess nobody has any advice?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Assuming your slab is level, a blue Walmart tarp will be fine. Once you get the water in it, it's not moving anywhere.
    -- Guy --
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    Thanks, yes its level. I was curious what most people do on a concrete slab. I may get the armor shield for padding, just a little pricey.
    Orlando, FL
    690
    The material that underneath is used to protect the pool from stuff that might damage the liner. So, since this is not expected to be an issue on the slab, I might go for a something that would provide a little cushion but will not stay wet and start to smell. That's my two cents.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    I've used just a tarp for 3 years. New setup/tarp each year and works out perfect, no smell/tear. I'm going to try it on some paver patio this year and see how it goes.
    Jun 2012
    MA
    347
    I would use a thin layer of sand and then a tarp.
    MrsDimples's Avatar
    Jun 2014
    England
    47
    I use EVA foam camping tiles. The sort that fit together.
    Intex 10ft Metal Frame - 1,185 gallons
    Intex 530 gall. per hour Filter Pump (Model No. 58604) - Cartridge
    Chlorine / pH dip sticks
    Intex 3kw Heater
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Some folks use sheets of foam housing insulation under the pool, taped together and cut to fit.
    Love TFP? Become a
    TFP Supporter!
