Results 1 to 7 of 7
Thread: any creative suggestions for repair?
    I've been staring at this deteriorated concrete around my skimmer deck lid for awhile.... There's water underneath it (duuuh) so it's not so easy as to simply concrete over, right?
    Any construction gurus out there with a creative solution that might not cost $100's and $100's?
    Appreciate your feedback as always!
    15000 gal. in ground quartz agg./ lazy L
    Pentair Whisperflow 1.5/Pentair FNS D.E. filter
    Solar Heat
    Hayward Navigator sweep
    San Diego, CA
    38,299
    Re: any creative suggestions for repair?
    I would think you would have to chip it all out, then put a form inside that you can pour concrete on top of. Maybe Styrofoam that you can then bust up to remove through the skimmer hole?
    Kind of depends what it looks like under that concrete.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Is it just sitting in there on a ledge or something? Can you pull it out, make a mold, cast a new one, put it back and put some deck-o-seal around it?
    Yes, in a matter of speaking. There is a recess below the deck level on the outer edges and then the remainder is hanging over the skimmer. I suppose a concrete professional could make a mold for sure...
    Thanks!
    Solar Heat
    San Diego, CA
    Hmmm...I kind of like where you are going with this.
    Didn't think about shoving some styrofoam under there. At one time I wondered if I could simply remove all the broken bits and fill it in with pre-mixed concrete as there is a piece of rebar in there to stabilize it. The rebar is in rough shape but likely serviceable. Under the broken bits of concrete is, well, nothing, but water and the tile at the bottom of the skimmer opening to the pool. Wondered what kind of bond I would get by attempting a repair rather than a complete re-do. Know what I mean?
    Thanks!
    Solar Heat
    San Diego, CA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    How thick is that? If it's 1" or less, you could slice through the sealer and lift the concrete out and replace it with plastic. http://www.boatoutfitters.com/cut-to...king-starboard
    Richard - it's a little thicker than an inch but I think it could be cut out and replaced with something else. A custom plastic cover would be a great idea provided that I could still easily access the skimmer to connect/disconnect pool sweeper as needed and clean out debris. Thank you very much!
    Solar Heat
    San Diego, CA
