Thread: Repair of Little Giant APCP-1700 Pool Cover Pump
    Apr 2015
    Branchburg
    1
    Forum,
    I kept my Little Giant Pool Cover Pump on my pool cover all winter long. As you all know, we had constant snow this past season. Now that the snow has all melted, the pump should drain my pool cover and it isn't. I took the cover off and checked the float. There is no obstruction. Any other ideas why it isn't triggering? I validated the outlet I have it plugged into has power. I would think this is a common problem.
    Any body have guess as to what I should do or try to get her pumping again?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Repair of Little Giant APCP-1700 Pool Cover Pump
    Welcome to TFP!
    No, but cover pumps are notorious for failing. Often easier to just replace. Sorry to give youu a lousy first responce, but perhaps someone will have a suggestion.
    Essential Links:
    wjr75's Avatar
    Jun 2013
    IL
    836
    Does your plug have a small white tube on it? You can blow into it to activate the pump. I had an animal chew on mine once that actually blocked the tube and the pump wouldn't start until I opened up the tube with a small nail.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
