Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Purchasing chemicals, where?
    Dec 2014
    Frisco/Texas
    45
    As a brand new pool owner (pool just got filled on Monday), I am wondering where people purchase their supplies. If you can tell me where and what brand you buy for the following, I would appreciate it:
    6% bleach.
    borax.
    baking soda.
    calcium chloride dihydrate.
    stabilizer.
    38,371
    Re: Purchasing chemicals, where?
    I would be shocked if you ever need baking soda or calcium chloride or borax for that matter in TX.
    Stabilizer(aka conditioner, cyanuric acid) you can get at pool stores or Walmart.
    There are a few threads that discuss the best places to find liquid chlorine ... there is really no 6% available any more. It is all 8.25% for the regular bleach or 10% / 12.5% from pool stores or in bulk.
    Do you have a Recommended Test Kit already?
    Please add your pool details to your signature as described HERE as it will help us help you.
    Aug 2013
    Hurst, Texas
    7
    Hello North Texas,
    In Hurst, the cheapest place to get 8.25% Bleach is always Wal-Mart - I don't care for Wal-Mart, but I do go there for Great Value Bleach - It's normally 2.94
    If you are new to this, the only thing you really need to watch for is the Production Dates. I once bought some Bleach on sale, by the case, and it ended up not working well at all.
    It would not raise Cl levels like it should, and it didn't last very long.
    After much heartache, and a lot of searching I found out that all of the "Case Price Bleach" was 14 months old.
    I was able to return everything that was not used - bought current date bleach, and all was well again.
    I have never had top buy any of the other products you asked about - Just Bleach for me.
    Once you get your stabilizer right, you really won't have to worry about that going forward.
    I would say get it to 40 or so and it should be fine.
    There is nothing you can "pour in" to get it down - so just be careful not to get it too high
    30k - IG - Plaster - Triton 60 Sand Filter - Zeolite Media - 1.5 h.p. Single Speed - Kreepy Krawly
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Please do not purchase Calcium Chloride, Baking Soda, or Borax until you post some numbers. +1 to Jblizzles comment.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    bleach. - I buy 8.25% Kroger brand concentrated bleach at Kroger or 10% liquid chlorine from Lowe's
    borax - 20 Team Mule Borax from Kroger, but as others say you need to wait until you know what you are doing and need/want to do this
    baking soda - Also from Kroger, but you probably don't need any
    calcium chloride dihydrate - I don't even know what this is.
    stabilizer - Pool chemical aisle at Lowe's
    You also will need muriatic acid which I also buy at Lowe's
    p.s.
    likely all you are going to need for a while is bleach to chlorinate and muriatic acid to keep the ph down, assuming you have a gunite/plaster pool. Hardness and alkalinity aren't really an issue here especially not at first.
    Dec 2014
    Frisco/Texas
    45
    Great. Thanks for all the help. I will post my test numbers shortly.
    Nov 2013
    Fort Worth, TX
    114
    Bleach....anywhere
    Muriatic acid.....Lowes
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Billrector View Post
    Bleach....anywhere
    Make sure it is 31.4%
    I am not certain about Lowes, but I know some big box stores are selling less than 15-25% strength for the same price as 31.4%
    Essential Links:
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by Patrick_B View Post
    yup, Lowes has both for about the same price. Blue label = 31.4%. Green label = lower % Low Fume
    Support the site
    May 2011
    Clearwater, FL.
    446
    My local Home Depot has 5lb jug of stabilizer ($20)and 2gal pack 31.4% Muriatic acid (can't remember how much)
    Lucky for me a pool store is 3/4 mile down on the street I live on.
    I get 10% 2.5gal carboys $5.15 out the door.
    Never really needed much else... never have to shock/slam, pool water is always perfect.
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Bleach 8.25% at walmart. 3.94 gal. The walmart brand
    Borax - I never have bought any. I dont need it.
    Baking Soda - Walmart in the pool section. 8.00 for a 12lb bag
    Stabilizer - Walmart pool section. HTH Brand, 15.00 for 4lb jug.
    Calcium Chloride - Walmart. HTH Brand (Calcium Plus or Calcium up or something like that) 9.00 for a 4 lb jug.
    Muriatic Acid - Hardware store about 300 yards from where woody lives. 7.25 gal.
    Quote Originally Posted by NorthTx! View Post
    6% bleach.
    borax.
    baking soda.
    stabilizer.
    Divin Dave,
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Bleach -- Big jugs of Great Value (bottom shelf) at Walmart, or the pool stuff in the garden center or Home Depot, depending on where I am during the week. I like using the 12% when I can get it but it's not any cheaper than the above. Honestly, when the pool is runnig well, I don't stock more than I need for a week or too and just but it while I am out doing other shopping.
    Borax - Walmart but the last box sat around so long it went back into the laundry room I don't need it often.
    Baking Soda - Walmart in the pool section. I don't need it often. Last bag got hard before I needed it again, I just broke off clumps.
    Stabilizer - Walmart pool section. HTH Brand, 15.00 for 4lb jug. I just but it when I need it, once... twice a year.
    -- Guy --
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: that 2 pack of MA at Home Depot- Unless you have a new pool whose pH rises constantly, I wouldn't suggest stocking up on the muriactic acid as I consider it a PITA to store. I only keep one jug at home, especially as I rarely need much of it. I wish I could buy smaller jugs of it just so I wouldn't have to store the extra.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    I only buy 1 gallon of acid at a time as well for a few reasons. I don't use much at a time and I have to keep it separate from other chemicals (don't ever store acids and oxidizers together!). I keep the jug outside, in a 5 gallon bucket with a lid.
    For the bleach, cheap stuff (8.25%) wherever you can find it. For the 10% and 12.5%, big box home centers and pool stores. My best deal near me is the 12.5%.
    Baking soda - grocery store. Much cheaper than buying Alkalinity Up at the pool store.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Dec 2014
    Frisco/Texas
    45
    Thanks, now for the big question.
    My pool was filled over last weekend and my PB guy came out on Monday afternoon and added some chemicals (not sure all what he added) and put us through pool school. Thus, last night (Wed) I tested the water. I had 0 chlorine and the Ph was low. I texted the guy who came out and he said Chlorine wouldn't show up in a test for a week.
    Is this true?????
    I'm concerned that my inline-chlorinator is not working. Should I add chlorine, wait, contact my PB to check out the chlorinator?
    Thanks
    17K gal IG Pool, 32' x 19.5' Dim w/86 ft Perim, 3.5-6.5' depth, Raised circular spa with 4 jets, 100% Quartz, Aruba Sky, Tile: Noble Rhodes Blue, 35' Moss rock wall notched into beam, 6' foot tanning ledge with steps off of it, OK Flagstone coping, 420' Paver decking, 2 skimmers, 5 returns, Del Ozone Ozonator, LED lights, Cleaner: Shark Vac XL, Hayward Equipment:425 sq. ft cartridge cleaner (C4030), Tristar Pump: 2hp, 2 speed
    Jan 2012
    7,364
    Is this true?????
    Thanks
    OMG! He really said *that*??? Oy. Chlorine is testable after minutes, just enough to circulate it well to get an accurately mixed sample of water. Now CYA (Stabilizer) does take about a week to appear on tests, but you go on the assumption it is in there (for whatever known amount you added, at the least).
    I don't know about your inline chlorinator but you need to get some good old bleach in their STAT! Otherwise you're asking for trouble from algae and any other contaminate that may have entered your pool in the mean time. Use PoolMath to tell you how much liquid bleach to use per your desired FC.
    PoolMath can also guide you in raising your low pH.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I suggest you buy a TF-100 test kit, do you own testing, add some chlorine and and never, never call that guy again.
    Inline chlorinators are nice for vacations, assuming you can afford the extra stabilizer in your water. If you plan for it, it can be nice to add a few pucks while you are out of time.
    -- Guy --
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Is this true?????
    Thanks
    Do you know for sure he added Pucks to the inline Chlorinator?
    If he did, and it has adequate flow, you should absolutely be seeing some FC residual by now.
    Since you are newly starting, you are losing a fair amount from sunlight each day because the stabilizer level is low. (Presuming he didn't add some)
    He shouldn't have with a new pool, and Pucks/Inline Chlorinators are great for new startup. The chlorinator should be adjusted to give you some residual that you should be seeing by now. It should not take a week.
    What are you using to test with? And as above, please add your pool details with the instructions link Jblizzle suggested in his post.
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    If you have a Food Lion near you, their brand "Home 360" regular bleach is 8.25% and $2.50 a gal......
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
  20. Back To Top    #20
    Dec 2014
    Frisco/Texas
    45
    I've added my signature. Not sure why it's not showing.
    17000 gallon in ground pool with Hayward equipment. Quartz plaster with chlorinater and ozonator.
    Testing with multiple kits. Here's what I get:
    FC: 0
    TC:0
    CYA: 30
    TA: 80
    PH: 7.4
    Phosphates: 500
