Results 1 to 11 of 11
Thread: Old pool pump.. dead.. new suggestions?
    Jun 2012
    Montgomery, AL
    10
    Hello all..
    A couple of weeks ago I went out to turn on my pool pump to start cleaning the pool up.(I left pump off all winter) When I turned it on, all I got was a low humming noise. I have taken the pump apart, cleaned all debris I could from impeller and tried to manually "turn" impeller with that large screw in the end of pump and it will not budge.
    I have read a few different things saying it's dead if I can't turn impeller. I am a complete newbie when dealing with pumps/motors but I am not afraid of DIY projects. The pump is at least 7 years old(came with the pool/house when we bought it) It is a Speck E91-II. Is it worth trying to repair myself or do I need to invest in a new one? If I need a new one, what would be a suitable replacement? (It has a "hi" and "low" speed, not sure if I actually need that though)
    I live in Montgomery, AL and the pool is 24' round and 4' deep. I have been using a SWG last couple of years.
    Thanks for reading and all information given!
    24' Round AGP - 13500
    Hayward Powerflo Matrix
    SWG
    Sand Filter
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Old pool pump.. dead.. new suggestions?
    Im afraid Im not much of help for above ground pump and Im sure someone will be along shortly to help you.
    But I would like to say, you definitely should stay with at least a 2 speed as you have now.
    Running on low speed will mean a LOT less electricy and low speed is just fine to keep your pool water filtered.
    The high speed would be used mostly for vacuuming and mixing chemicals into the water.
    Sorry I couldnt offer more adivce.
    Divin Dave,
    Orlando, FL
    690
    Have you searched, pump buzzing? This thread might be helpful
    http://www.troublefreepool.com/threa...-does-not-pump
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    38,299
    The fact that you can not turn the motor means that it is not just a capacitor that needs replaced. Seems like the bearings must be seized up, which is a good bit more work to fix.
    I would suggest just getting a similar 2-speed motor and put it back on your existing pump. Get a set of seals while you are at it, definitely need the shaft seal at least.
    Were you running the pump on low speed for filtering and then just bumping up to high for vacuuming or backwashing?
    Jun 2012
    Montgomery, AL
    10
    Yes, I was running pump on low speed for filter and rarely turned on high speed. "Get a set of seals/ shaft seal" Are these all standard or different sizes/types? Is there a certain brand or type I should be looking for as far as the motor? Any to avoid?
    Thanks all for information.
    SWG
    Sand Filter
    38,299
    Seal kits are a function of you pump model. You should be able to search for the equivalent of you exiting motor. I am not aware of good or bad brands.
    Jun 2012
    Montgomery, AL
    10
    Ok, so I found a pump for what I thought was a good price but now I am having trouble with connecting the pump to my plumbing. (I feel like such a frustrated idiot) Is there a way(adapter or similar) I can use the unions from my old pump with new one (New one is Hayward: powerflo matrix) to connect the "in" and "out" hoses/pipes? Here are a few pictures that I thought would help. I am a total novice at any type of plumbing/fittings. Thanks for any and all help or Info you may have for me! (The union is just a Tab bit small to screw on to the new pump)
    SWG
    Sand Filter
    Feb 2012
    Memphis, TN
    52
    You should be able to make something work at Home Depot's pvc pipe section.
    11,000 gal Fiberglass IG, Jacuzzi sand filter, Pentair Superflo 1.5hp 2speed pump, Hayward AQR15, Maytronics Active20, K-2006 kit, K1766, SpeedStir
    38,299
    Manufacturers seem to use proprietary unions ... so not surprised the old ones will not fit. Plus I am sure the inlet and outlet are not in the same locations anyway.
    You can just use a male threaded fitting into the pump and then add a regular union in the pipe if desired ... or you may be able to find a set of the Hayward unions that would fit the pump directly.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Nothing to add, just wanted to say nice to see someone on TFP from Montgomery
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    You might not be able to get what you need at a big box store. The selection of 1.5 inch at my local stores is pretty limited and 2" is really hard to find. For the fittings right at the pump they usually are something that are different and proprietary from one manufacturer to another. That's where you might need to do your shopping on line at a pool supply company.
    I know my new to me Hayward leaked from day one because whoever installed it tried to use a regular PVC fitting at the pump and the Hayward wanted one of it's own O ring fittings. The Hayward fitting solved the constant slow leak.
    Solar Blanket, Well Water, Borax Added. 68
