Thread: Pump basket only half full
    Mar 2015
    San Francisco
    1
    I have a carridge filter. Why would the "skimmer" basket on the pump only be half full of water. Everything is clean. Cartridges rinsed. ??????????
    38,275
    Re: Pump basket only half full
    Welcome to TFP!!!
    The simple answer is that you are sucking in air between the pool (skimmer/floor) and the pump impeller.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Welcome!
    Air in the strainer is caused by a suction side leak. The most common is the Oring on the lid. It needs to be clean, lubricated, and free of cracks. Next most popular is low water level and/or a stuck weir door (skimmer flapper). If you try the search box for suction air leak, you'll find more than you ever wanted to know.
    A variable speed pump running on a low speed will sometimes do this even without an air leak. If there isn't an air leak, you won't lose prime. If you are losing prime, or running a single speed, or two speed pump, or running a variable speed pump at half speed or higher, there must be an air leak.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Gary
    Solar Blanket, Well Water, Borax Added. 68
