Thread: Pool drain not working
    Jan 2013
    Atlanta, GA
    13
    Basically we bought this house with a pool few years ago. I didn't really pay attention but now I think that the main drain in the bottom of the pool isn't connected to the pool pump. I installed a swg and accidentally poured too much salt in the deep end. With the pool pump running, I brushed the extra salt over the main drain to see if it would suck it and try to dissolve faster. What ended up happening was the salt just sat ontop of the drain and never moved and just piled up.
    The pool has 1 main drain in the deep end, 2 skimmers and a connected spa with 2 drains. I attached a picture showing what each inlet pipe does.
    Could the main drain be clogged? But wouldn't I have another main drain pvc going to the pump? I tried to dig down around the other pipes to see if they just capped it off for some reason.
    What are my options?
    Thanks for any feedback.
    Built 1994 25k IG plaster pool with waterfall spa, 1.5 HP Standard Motor - Full Rate , Hayward S244S Sand Filter
    Polaris 380 Pool Cleaner, TF-100 test kit
    Mar 2015
    Plano, TX
    18
    Re: Pool drain not working
    It's possible the one of the skimmers is a combination skimmer, and is plumbed to the main drain. Look under your skimmer baskets - is there one or two holes? This is how a combination skimmer is plumbed: http://blog.poolcenter.com/article.aspx?articleid=6327
    1982 built 15K? gallon IG gunite/plaster, DE filter, Pentair Challenger 1.5HP pump, Polaris 280, Pentair LA01N booster pump, 3-8' with diving board, K-2006 test kit
    38,260
    ward1983 may be on to something.
    If the floor is plumbed to one of the skimmers (which is likely), if you do not have a float diverter under the skimmer basket, you will not get any suction from the floor.
    You have more investigating to do
    Jan 2013
    Atlanta, GA
    13
    Thanks for the tip. I just checked while 1 skimmer has 2 holes, 1 of the holes is plugged, while the other skimmer does have 2 holes.
    I went ahead and order a Float Assembly with O-Ring Replacement,
    38,260
    That should do it ... the extra hole in the one skimmer has to be where the floor is tied it
