Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Pipes
    Mar 2015
    Santa Ana
    9
    Pipes
    My waterfall piping is leaking and I don't know what sort of pipes I need to replace them with. They broke where they rub against the rocks.
    The existing pipes are neither the flexible ones nor the solid pvc pipes. The pipes are curved so they can bend to some degree.
    I have attached Photo.
    Any suggestions of the name of these pipes and where I can buy them from would be greatly appreciated.
    Thx
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,015
    Re: Pipes
    Hi and welcome to TFP!
    that black pipe is known as Poly Pipe. It's commonly used in the lawn and commercial irrigation industry.
    Probably your best bet is to call around plumbing supply shops.
    Lowes and Home Depot have it in smaller diameters, but not sure about larger ones, but you migh google HD or Lowes and see.
    Divin Dave,
    Mar 2015
    Santa Ana
    9
    Re: Pipes
    Thank you
    Feb 2014
    Upstate, NY
    390
    Re: Pipes
    You could replace it with flex PVC. http://www.spadepot.com/shop/Flex-Pi...-P812C662.aspx
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,015
    Re: Pipes
    Donny is right. It could be replaced with Flex PVC. You could even hard plumb it too and then paint the PVC pipe so it blends in with your landscape
    Divin Dave,
    Mar 2015
    Santa Ana
    9
    Re: Pipes
    It would be too difficult to hard plumb. Which is stronger? Poly pipe or flex pvc? The pipe will probably rub against rocks
    Feb 2014
    Upstate, NY
    390
    Re: Pipes
    I would use the flex PVC. You will be able to install it around and away from the rocks easier. I do not know the exact specs on each, but I can tell you the flex PVC is plenty strong and used by pool builders. (I have it installed in my pool ) Another benefit of the flex PVC is less fittings. Less fittings=less chance of leaks. I think it would offer a neater install too. Just my opinion though.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Pipes
    Flex PVC is plenty strong. It is a little trickier to glue the joints. Use the right stuff and allow plenty of cure time.
    Mar 2015
    Santa Ana
    9
    Re: Pipes
    Final question. I can't avoid the rocks. The rocks are part of the water fall and the pipes will need to go between the rocks. Do you still recommend flex pvc?
    Feb 2014
    Upstate, NY
    390
    Re: Pipes
    Quote Originally Posted by stuart.faircloth View Post
    I do.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,015
    Re: Pipes
    Poly pipe is meant to be inexpensive and to be truthful, should never have been used in this application. It was an inexpenive deal done by whomever did it.
    PVC flex is the better choice.
    Divin Dave,
    Feb 2014
    Upstate, NY
    390
    Re: Pipes
    Quote Originally Posted by Divin Dave View Post
    Dave summed it up pretty well.
    38,524
    Re: Pipes
    I would recommend using hard Sch 40 PVC anywhere you can and only using the Flex (which is quite expensive) where you have to.
    Your picture does not provide enough of a view to get a clear idea of what you are dealing with.
    Mar 2015
    Santa Ana
    9
    Re: Pipes
    Here are some more photos. The water is pumped from the basin to the top of the waterfall around the rocks to the left. There are 3 spouts at the top of the rocks (hidden in the rocks) that pour water into the basin.
    uploadfromtaptalk1428132375625.jpguploadfromtaptalk1428132397850.jpguploadfromtaptalk1428132411408.jpg
    Feb 2014
    Upstate, NY
    390
    Re: Pipes
    I'm going to assume they used the Black irrigation pipe because it has more flex to it than rigid schedule 40 PVC. If you do not have any straight runs, you will have to use the Flex pipe. Ask yourself this question as well ? How long did the current set-up last ?? Answer, probably years. Whatever route you decide on, I wouldn't sweat it too much. The new set-up will last longer.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: Pipes
    Whatever you decide upon... you could wrap it with foam pipe insulation (or slit a pool noodle) to keep it from chafing.
    Mar 2015
    Santa Ana
    9
    Re: Pipes
    So, I took everyones advice and I think I can make it work with schedule 40 piping, but I need some advice. I am limited in what I can do due to the rocks.
    It's hard to see from the picture, but the water will enter at the top and hit a t junction. The water will flow to the left and right. The problem with the water flowing to the right is that it will flow through the second pipe and never make it to the third pipe on the right. Any tricks I can use to divert the water to the third pipe?
    38,524
    Re: Pipes
    Have a loop in the feed so the pressure to each pipe is balanced?
  20. Back To Top    #20
    Mar 2015
    Santa Ana
    9
    Re: Pipes
    Sorry for my ignorance. But what does a loop in the feed mean?
