Results 1 to 16 of 16
Thread: pump o rings
    rajung's Avatar
    Mar 2015
    Iowa
    187
    pump o rings
    Well I got the pool up and running,all parts were stored indoors during winter.
    I have had the pump running about 6 hrs, no problem.
    Now I see a drip only while its running around the band clamp that connects the strainer basket to the main unit.I haven't separated yet but wanted to do a search for o rings and such.According to my parts breakdown, there are 3 o rings,a spring seal and a ceramic seal.
    Anyone have one of these pumps that had a leak in the same area?
    Doughboy parts express has the spring seal and ceramic seal but don't list any o rings .
    Really hate to go to my one and only doughboy dealer for 3 o rings.Out of state retailers wont sell.What a racket.
    o ring sizes- 5.300" x .125"----1.740" x .125" and 1.29" x .103"
    Just curious for any ideas, pump only 3 years old but after 90 days labor not covered.
    I don't want to spend for travel charges and labor for 3.00 in parts.
    thanks
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    Re: pump o rings
    Leaks like that one are almost always the ceramic seal. Second most common is cracks in the pump body. It is very uncommon for the o-rings to fail.
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: pump o rings
    Thanks for the quick reply.
    Is that fairly common also to last about 3 years? since running the pump I always let it run 24/7.
    I know many people have the Doughboy line of equipment but very few if any have the pumps and other items.In your opinion, is this the same reason why?Part availability for do it yourselfers?
    Re: pump o rings
    Doughboy pools are great, but their pumps are only so so. Still, on average they normally go longer than 3 years without a problem.
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: pump o rings
    I ordered 2 ceramic seal sets but not through Doughboy, hopefully the right size,5/8", from what I found this part number has multiple cross reference numbers and used in a lot of pumps.2 sets for 1/4 the $ of 1.(US seals ps-1000)
    Are there any special tools needed?I have looked online for videos and such but nothing as for my particular pump,all for Hayward and other over the counter type pumps.thanks
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: pump o rings
    Well, after shocking to the pool today, and running the pump, after about 8 hours, just checked, the pump isn't leaking.
    I was re staining the deck and checked off and on and it appeared to slow down every couple hours.Now nothing and the pump is still running.
    Any thoughts?seals on order but cant think ceramic seal would self heal.
    I guess after the chlorine mixes I will shut off for a few hours and re start and check again.
    Re: pump o rings
    A suction side leak would only let water out when the pump was off. When the pump is on it lets air in.
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: pump o rings
    Well today is back to dripping, seals arrived but haven't installed.
    Jason, confused on the reply.
    thanks
    Re: pump o rings
    You said the pump had been running all day and hadn't leaked. If it only leaks when off, the leak is on the suction side of the pump, not the pressure side. If it leaks all the time, the leak is on the pressure side of the pump. That might help you narrow down where it is leaking, or it might not.
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: pump o rings
    don't know why it quit a couple days ago.
    After the pump is off,its dry after about 4hrs.Once I start back up the next morning it starts dripping again, not terrible, but about a drop every 3-5 sec.
    Not bad but hate to have it suddenly get worse if I'm not around while it running.
    Thanks again.
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: pump o rings
    Seals arrived today.
    Replaced.
    No leaks.Not the easiest to do on the Doughboy, no way to drive seal out on the impeller side,had to carefully pry out.
    Thanks for all advice.
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: pump o rings
    well forget about no leaks!
    pump ran all night,shut off around 10am,worked on timer, turned pump on and it shoots a big stream straight out from band clamp for about 2 seconds.
    Took cover off motor and the area behind the ceramic seal is dry at the pump shaft and no water on the bottom of housing, so I assume the ceramic seal is holding.
    I can shut the pump off and back on and the same stream happens for a couple seconds and the slows to a drip, and maybe even stops.
    I am thinking the unit builds up pressure when shut off and doing something with the o rings, may have been my original problem?
    Bottom of pump case and shaft area was dry also before replaceing seal.
    Any ideas?
    I added a youtube link for a quick video I had taken, it does quit leaking and I think just drips off the rest of accumulated water arounfd clamp.Doesn't matter if I shut off for5 sec. or 5 min. same results.
    http://youtu.be/ciqsNlrN6bg
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: pump o rings
    Is there an o-ring in between the two pieces held by that clamp? Did you lube it? Can the clamp be tightened more?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: pump o rings
    there are 2 o rings on back side of volute # 14 image only shows one, also one on the front of it, so needless to say my owners manual is also wrong, i lubed them , no cracks,and the band clamp inst adjustable, it pivots by a bolt hinge and just a cam flip over lever/hook.
    Attachment 35109
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: pump o rings
    Well, hopefully I can end this post.
    Called my local Doughboy dealer about some o-rings.
    He was looking at the same parts breakdown as me and said he only sees 1 o ring behind volute.
    I ordered 2 since they are the same size.
    Mind you this was a new pump with new pools Aug. 2012
    First time I had the strainer basket off .
    I decided to take apart again before the new seals showed up.
    I left the o ring that was installed in the groove, but removed the o ring that was installed towards the front area near the flange where clamp goes around, no groove.
    Since all parts break downs I see only show one seal.
    Guess what?
    Doesn't leak.
    I have tried throughout the day turning off and restarting.
    Next pump will not be a DB-parts are nuts to find and this 2.5 yr old unit I found out is discontinued.
    Must have been sold a pump already taken apart and re assembled by Herbie the wanna be dentist.
    Thanks all for the info.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: pump o rings
    If one o-ring is good, two must be better. At least according to Herbie, huh.
