Thread: water chemistry
    Mar 2015
    South Texas
    411
    water chemistry
    So I'm getting a SWG and the chemistry recommendations of the manufacturer (Autopilot) differ slightly from the recommendations on this site. Most notably, TFP recommends CYA 70-80 and FC at 5-8 while Autopilot recommends CYA of 30-50 with FC between 2-4.
    Any thoughts on this?
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: water chemistry
    Quote Originally Posted by nlindelldc View Post
    I wouldn't run the CYA lower than 40-50 in TX.(with a SWG, I'd run 70-80) The higher CYA recommendation will yield better protection for the FC from the sun...which will mean your SWG will run less...which will make it last longer.
    FC, use the FC/CYA chart. remember that the relationship is extremely important.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    38,292
    Re: water chemistry
    In TX, you want the higher CYA level for more protection of the FC from the sun. This will make the SWG cell last longer as well since it will not have to work as hard.
    Mar 2015
    South Texas
    411
    Re: water chemistry
    That makes total sense. Thanks guys.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: water chemistry
    i live in Ft Worth and I run my CYA at 70-80.
    The recomended levels on this site have worked perfect for me for the last 3 years.
    all I ever have to do in the summer is add some acid.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: water chemistry
    Nothing new to add ... 70-80. works great!
    Divin Dave,
