Thread: Intellicolor controller?
    Dec 2014
    Riverside California
    482
    Hello, all. As part of my pool remodel, I will be replacing two pool lights and one spa light with Intellibrite fixtures. I currently have a Compool LX10/Timemaster system which I will be upgrading to an Easytouch system. My question is, do I need the Intellibrite Controller or can The Easytouch system control the lights in the same manner as the controller?
    Thanks for any help, just do not want the expense of the controller if the Easytouch will do the same thing.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Re: Intellicolor controller?
    The EasyTouch can control the lights very flexibly, even without the IntelliBrite Controller. The one advantage of the IntelliBrite is it has dedicated buttons for each color. The EasyTouch can actually do more things with the lights, it just takes an extra tap or two.
    Mar 2011
    441
    Ditto on above.. If you have both an intellibrite control and an easy touch it will just end up confusing the issue.
    20X40 30,000 gallon gunite pool
    Dec 2014
    482
    Thanks, JasonLion and racket. Just the info I was looking for. I will not install the Intellibrite Controller.
