Results 1 to 8 of 8
Thread: New Pool Owner - Might dynomite soon
    Mar 2015
    Fulshear, TX
    2
    I don't even know where to begin...For the first time in my life I feel like a complete idiot. I've kicked butt in all other "schools", but pool school...I'd rather go back to grad school. This large hole with water is my nemesis, yet I'm determined it will not beat me. It was completed and filled in mid February. We just started adding chlorine 10 days ago when the pool temp reached 70 degrees. Maybe we waited to long - No clue, BUT I took my water to Lesley's Pool Supply this morning due to an inability to get the chlorine up to an acceptable rate and the results are in: We are failing as pool parents. Our Ph is great. We are proud of this. It's all we have... Any good pool therapy out there? I miss the good ole days already when my feet were hanging outside of a 4 ft. diameter inflatable pool. Water was unsatisfactory? No prob! Dump it out and put the hose back in. Sigh...
    Allison Walla
    Terrified of my newly installed 20,500 gallon in-ground chlorine pool in Fulshear, TX
    I look forward to changing/modifying the above signature. ;)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: New Pool Owner - Might dynomite soon
    Welcome!
    Mistake number one: trusting the pool store. Their free testing is seldom free. How much did they take from you this last trip? How high are your phosphates? Not that they make any difference in a wellmaintained pool, but phosphate removers are a highprofit item.
    Right now, before you read anything else, order a proper test kit. You can read the comparisons in Test Kits Compared, or just skip it and order a TF100. No, I do not get a kickback, but it is what I use.
    Others will be along -- if they haven't typed faster than me already - with lists of pool school articles to read. So instead, I will refer you to a thread with some of my favorite threads. http://www.troublefreepool.com/threa...rational-links
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Hi Allison and welcome!
    You haven't failed as a new pool parent or you wouldn't be here. Pool School is a bit daunting at first but read and then read again. It all starts to make sense eventually.
    But first, decide who is going to advise you about your pool...the pool store? Those methods don't often jive with the teachings here. So I recommend you for the job! Armed with the knowledge of these forums and advice of the experts here, you will have a clear, sparkling pool in no time.
    And everything begins with accurate testing. Have you ordered a good test kit yet? No? Ok, here's a handy reference to help you choose.
    http://www.troublefreepool.com/conte...its-comparison TF-100 is very popular here and if you have visible algae, I would order the XL kit. It is the single best investment you will ever make. While you're waiting for delivery, keep reading Pool School. After your first set of test results, post them back to this thread if you would like advice on your next steps.
    Oh, and pictures please! They just make things more interesting, ya know?
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Quote Originally Posted by allisonwalla View Post
    Welcome to the forum. You've come to the right place. get on that TF100 test kit as directed above. While you wait, look at the pool school, ABC's of water chemistry is a great place to start.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    38,539
    Welcome to TFP!!!
    Please step away from the wick and extinguish the lighter
    We recommend "opening" pools before the water get over 60 degrees ... so do that late along with trusting the pool store have got you off to a bad start. Luckily it is easy to fix with a little investment of money and time learning.
    I agree with the others, order the TF-100, XL option would be good + the SpeedStir if you can swing it. This small investment will make your pool life so much easier.
    While waiting, these are some good articles to start with in Pool School:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    And always ask questions as they arise
    minxcal's Avatar
    Jul 2013
    South FL
    80
    I'm just going to say... If I can figure this out, and you have a Masters, you certainly can. Breathe deep, order a test kit and Speed Stir (and get an extra stirring "pill" while you're at it - trust me), visit your nearby warehouse store and pick up some bleach, go back to the pool store only for a Wall Whale brush, and ask questions. This forum and the people in it are so helpful. Your pool will be clear and inviting in no time.
    17' x 30' plaster pool, Intellipro Variable Speed pump, filter that's about to be replaced, 1 skimmer and 2 returns, and that's about all I know about this pool!
    4' ledge all the way around, deep "scoop" about 9' deep - NO DIVING!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Hi Allison,
    everything you have read on this thread so far is true. THere are a few things you need to know, while you are learning.
    The levels that you need your water parameters are in this link.
    http://www.troublefreepool.com/conte...mmended-levels
    If you dont keep your FC in proper ratio with CYA (a.k.a. stabilier or conditioner), then you will get algae, no matter what you throw in to prevent it.
    http://www.troublefreepool.com/conte...art-slam-shock
    So how to know how much of what to put in? Well we happen to have this snazzy little tool called Pool Math. You will use this for as long as you have a pool.
    http://www.troublefreepool.com/calc.html
    Now, get yourself a test kit. The TF100 is the best bang for the buck. www.tftestkits.net
    Pool store testing as well as their advice is unfortunatley, very inaccurate.
    If you hang out here at TFP and do a little reading, you will gain the knowledge needed to efficiently and effectively take care of your pool.
    I also look forward to seeing you improving that signature!
    Divin Dave,
    May 2011
    Clearwater, FL.
    446
    I felt the same way with my first intex pool!
    Learned here how to properly care for it with my TF-100 kit with TFP forum and loved it so much after 2 years got a bigger pool.
    Post back and we can help, we all have been there and started as a newbie!
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
