Thread: AquaRite / Goldline Control Panel No Power
    Mar 2015
    Melbourne, FL
    3
    Hi all,
    I have a control panel that is completely that is not showing any power. I had this issue last year and soldered a new quarter sized capacitor on the back, which fixed the issue. I did the same last year and it corrected the problem however this time its not the case. I did smell a sort of burning smell coming from the control panel last week and I assume it is the transformer. I do know that the box is getting power because the line going to it is hot. Are there any other resistors or capacitors on these that are prone to failure? My unit is about 10 years old and I am considering just adding chlorine for the time being until this is resolved.
    Thanks in advance for your help.
    38,475
    Re: AquaRite / Goldline Control Panel No Power
    Welcome to TFP!!!
    Well I would have suspected the current limiter but sounds like you already tried that.
    You should definitely be adding liquid chlorine to maintain adequate FC levels until you get the SWG sorted ... or your pool may quickly go green.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Have you tried testing the voltage on the output side of the big transformer?
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Mar 2015
    Melbourne, FL
    3
    I have not yet but that was going to be my next move. I'm hoping that is the issue so I do not have to buy a new board.
