Results 1 to 8 of 8
Thread: Pool timer doesn't turn?
    Feb 2014
    dfw tx
    67
    Guess the pool timer died its an intermatic PF1102T and it is about 10+years old. Should I change out the whole unit or is there usually 1 thing that goes wrong related to the timer?
    16k gallons
    IG "roman style" plaster
    Pentair CCP420 Clean and Clear Plus Pool and Spa Cartridge Filter, 150-GPM
    1hp pump
    Built in 2000
    Re: Pool timer doesn't turn?
    If you are up for a fairly simple DIY repair, the motor that turns the timer wheel can be replaced without replacing the entire timer.
    Jun 2013
    Huffman Tx
    190
    there is an inspection window . you can look behind the metal face in a little hole and see if motor gear is turning. on a . Intermatic brand
    Feb 2014
    dfw tx
    67
    Quote Originally Posted by JasonLion View Post
    http://www.amazon.com/Intermatic-Tim...ol+timer+motor
    like one of these? I'll pull it before ordering it to compare part numbers of course
    16k gallons
    1hp pump
    Built in 2000
    Yes, very much like that. Double check the part number and you are good to go.
    Feb 2014
    dfw tx
    67
    Just installed a brand new complete timer and its still not turning off. Even with the tab closed it still runs but now it does turn , so the only other thing it can be would be the relay?
    16k gallons
    1hp pump
    Built in 2000
    The freeze protection portion of those timers sometimes get stuck on. Try turning the freeze protection knob all the way through it's range and then back down to the coldest setting and see if that gets it unstuck.
    Feb 2014
    dfw tx
    67
    Tried it still turns on with all the tabs down.
    16k gallons
    1hp pump
    Built in 2000
