Results 1 to 14 of 14
Thread: attic heat exchangers for pool heating
    Jul 2008
    Solon, Iowa
    170
    I haven't seen these discussed much. Do we have any users here? Since my attic is usually unbearable on sunny days, I'm intrigued by the thought of pumping my pool water up there and into a heat exchanger. Thought I'd seek info from experienced users before going this route vs solar panels.
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    Apr 2008
    Central Texas
    326
    Re: attic heat exchangers for pool heating
    I've read through the web site for this one: http://www.solarattic.com/ But I have a problem with any company that won't list their prices in public. Either the price is insanely high or it varies depending on how badly they want to sell one that day. Makes me pretty skeptical...
    The concept seems good, but my attic gets the hottest when I don't need the pool heated. I also would be concerned about having that much water flowing through my attic. A leak or break could flood the house out pretty badly if no one was home to notice it.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Mar 2008
    Wake Forest, NC
    128
    I am sure that it will work just fine. I however would not want water in my attic. Having been through a run away wash flood I could only imagine what broken pool pluming would do. I have all of my equipment in my garage. My pool is 10 degrees warmer than my neighbors pool at any given time. Yes, it gets real warm when I don't want it to. It does however warm up real quick in the spring.
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
    Mar 2007
    San Rafael, CA USA
    12,082
    Using a solar panel on the roof would be more efficient since such panels are typically 80% efficient and absorbing 90+% of the sun's energy (with the difference representing thermal losses back to the air). In our original solar installation, there was no panel over our bedroom and that was the hottest room in the house with sun on that part of the roof longer than any other area. So we had another panel added (over the bedroom) and it has made a HUGE difference in keeping the room cooler and a small improvement in keeping the pool water warmer. It was an unanticipated, but positive, side effect. Pulling the heat from the sun into the pool before it heats the roof, attic, and room below has worked out well.
    On the hottest days, the solar turns off early as the pool reaches the desired temperature so the removal of heat stops at that point. So we don't get that maximum cooling on the hottest days (unless we want our pool to be 90+F).
    Richard
    Check this site for an interesting take on heating your pool.
    http://www.redneckpoolheater.com/
    21 x 41 Oval AGP (24,000 Gallons)
    Sand Filter
    TF-100 Test Kit
    Mar 2008
    Wake Forest, NC
    128
    Quote Originally Posted by greggsteven
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    I saw that Redneck heater a while ago when I thought about doing the same thing. I wonder how efficient it is?
    Also, I agree with Chem Geek. Using solar panels o top of the roof has many advatages. First, if a solar panel breaks, it's ouside the house so nothing floods. Second, solar panels are cheaper to operate being that they don't need to run anyhing extra(compressor, fan motor). And third, Solar panels are more efficient as Chem Geek pointed out. They are probably cheaper to.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Guest
    Quote Originally Posted by kjcole
    Kelly
    You know your attic is hot because of the sun hitting the roof, right?
    If you have solar panels, which are designed for the roof and keep the water outside of your house, your attic will be cooler. The solar panels will absorb the energy, therefore cooling your attic.
    I would just go with solar panels and skip this unproven technology. Solar has been around for 30 years for pools (we had the FAFCO system in the 70's in Pennsylvania).
    Just my opinion.
    Jul 2008
    Solon, Iowa
    170
    I'll go with solar panels, but probably at ground level on the south side of my house (unobstructed) since I have a 2 1/2 story home with a fairly steep pitch to the roof.
    Kelly
    Jul 2008
    Dallas, Texas
    27
    Yeah, as a general rule that I think is good to follow you want water out of your house not in it.
    Brian
    30,000 Gallon Renovated Pool and Spa
    Flagstone Coping and Wall
    Onyx Quartz Plaster
    72 SF D.E Filter
    Polaris 280 Cleaner
    Jandy Aqualink Control Center and Palm Remote
    Apr 2009
    Minneapolis, MN
    2
    Hello everyone,
    I work for the company and can address the concerns of our pool heaters leaking into the attic please email for information.
    Thanks James
    James Kantorowicz
    SolarAttic, Inc
    15548 95th Circle NE
    Elk River, MN 55330
    763-441-3440
    Apr 2009
    Minneapolis, MN
    2
    As I stated in a previous post I work for SolarAttic however I do want to address one of the major concerns expressed in this forum. The potential of leaking and pumping thousands of gallons into the attic.
    1st lets remember what causes a pool heater to fail in the first place.
    Fossil Fuel Heaters ( Gas- LP ) use a flame burner heating up the coils and water to high temperatures eventually causing the coil to fail and leak. This typically will occur within 7-10 years.
    Heat Pumps: contain a condenser which puts extremely high pressure and heat in the neighborhood of 150-180 degrees. That is why a quality heat pump will use a less efficient titanium core to hold up from continuous heat and pressure, otherwise a copper coil would quickly erode and start to leak within a couple of years.
    The SolarAttic Pool Heaters have neither a flame burner or condenser the two main causes of pool heater failure.
    Now lets talk pressure: Each and every coil that is put into our systems are tested at a continuos PSI of 450 if you were to put any other pool heater on the market through this test they would simply blow apart. The average inline plumbing pressure inside the SolarAttic pool heater is a continuous PSI of 20. To put that into perspective its about a 1/3 of the pressure than what is currently in your domestic water plumbing inside your walls.
    So now you take out the burner, condenser, and pressure what else could go wrong and cause this system to leak? Some say plumbing itself could start leaking inside the attic. Ask any plumber the weakest point of any plumbing is the connections and joints in the plumbing lines. We recommend using a Schedule 40 flex pvc connected outside the overhang and run a continuous pipe to the heater in which it is connected inside the attic. This means no joint or connections in the attic that could leak over time. By connecting the pipe outside the attic if it dripped it would be outside or if it leaked at the connection of the heater it would sense the moisture and shut off. The controller would refuse to turn on the system protecting the home owner from possible leaking into the attic. FYI: Solar panels are prone to leak causing home damage that is why in most states you are required by the insurance company to carry additional coverage incase of the panels leak and damage the home.
    To recap it all: Our systems do not have a flame burner, condenser, high PSI or have issues of leaking into the attic. Im do apologize for such a lengthy post but to my knowledge not one person in this forum contact me direct to discuss the potential of leaking into the attic so I brought the information here.
    Now I put out the invite again if you still have concerns about our units just give me a call or shoot me a email and lets talk about it.
    FYI: SolarAttic manufacturing alternative solar pool heaters for 23 years. Our pool heaters are 100% made in the USA and CSA certified.
    James Kantorowicz
    SolarAttic, Inc
    Elk River, MN 55330
    763-441-3440
    Dec 2010
    Massachusetts
    50
    James, re the solar attic.
    Why don;t you make the coil of cupro-nickel or titanium to last longer? From what I understand it is built with a copper coil.
    I have a salt water chlorinator and fear the copper will corrode. Can you shed some light on this?
    Thanks
    Dec 2009
    Central Massachusetts
    2,690
    This is a two year old thread, i doubt james is still around.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
