Results 1 to 7 of 7
Thread: Now What Do
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Now What Do
    Pool looks great after 1 year on TFP..Thanks to the supporters of this forums.. Thank you all..
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Now What Do
    Quote Originally Posted by boston62 View Post
    looks great! congrats on keeping it looking great!
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Now What Do
    That's fantastic!
    A bad side effect of TFPC is that managing a pool can be less than exciting. You'll have to find a way to create your own pool chemistry drama now.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Now What Do
    Go swimming?
    Orlando, FL
    690
    Re: Now What Do
    Sit back and relax. If you are like me, you will spend time dreading what you believe to be the inevitable. No, you should listen to Richard IF your water is also warm.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Now What Do
    Take your chemistry skills to the bar and mix up something tasty!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Now What Do
    Thats some nice shimmering going on in that pool!
    Divin Dave,
