Results 1 to 8 of 8
Thread: Cloudy
    Mar 2015
    Naples fl
    25
    Cloudy
    Hey team! So I moved into my new house, pool was greenish and algae. I put two gallons of chlorine and a little acid in the pool and a day later it was all gone. Rinsed out the filter and brought a sample to local,pool place. They gave me stabilizer/conditioner and total alkalinity increased to put in pool. Water is still a little cloudy. I ran pool pump for 6 hours yesterday and it is running now at 8 am. Does it need more time to filter or do I need more chemicals?
    12000 gal IG spa attached Hayward pool pump and filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Cloudy
    Welcome to TFP!
    I would really like to help you, but we need more information. My best advice is that you'll need a proper kit to handle this correctly if you want to do it yourself. Mixing our advice with Pool Store advice and suggestions will give mixed and poor results.
    Do you have the latest full set of numbers they got on your water? It might be something to work with, but Unfortunately stores often have inconsistent and just as often inaccurate numbers.
    Our cornerstone however is knowledge. Knowing what you put in, and why. All that information is here, and it's free. You can start building it, beginning with the ABCs in Pool School. Without some numbers our advice is minimal. I would suggest a proper test kit, not strips, and not adding more Alkalinity up, Cya(stabizer) or similar until we know some facts.
    Essential Links:
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Cloudy
    Like Patrick said, without a reliable test, you are guessing. Pools Store tests are very good at finding ways to spend your money but not actually solve your problems. I don't think I would ever start with stabilizer to clear cloudiness from a pool. It is what you add after the pool is clean and stable to protect your chlorine, to a certain level.
    If you have a cloudy pool, it is likely algae making it cloudy and liquid chlorine is best tool for this. how much? it depends on your CYA, PH and other test results.
    -- Guy --
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Cloudy
    I'm going to add my two cents here as well.
    Pool School (link at the top of the page), and a good test kit.
    What we mean by a good test kit is a FAS-DPD test kit. Your pool store test kits will only test to a low level of sanitizer, and you will need one that test higher. Details are in Pool School. Recommended kits are the TF-100, or the Taylor K-2006. Don't let the pool store sell you the K-2005, as it is NOT the same as the K-2006. The money spent on one of the recommended kits isn't an expense, it is an investment. Once you learn how to use it, it will save you many times it's price in both time and money in just the first season of use.
    As the other replies have noted, what we have here is knowledge and all the help you could want. We will show you how to care for your pool in the most economical and least time intensive methods you will ever find.
    Mar 2015
    Naples fl
    25
    Re: Cloudy
    Thanks guys. I've been working on it. Pool is crystal clear. I've been reading up. Y'all rock!
    13000 gal IG
    Hayward pump 1 1/2 hp
    Hayward star clear plus filter system (DE)
    Attached spa
    Covered lanai
    Casey's Avatar
    SW PA
    10,453
    Re: Cloudy
    Did you order a test kit?
    Mar 2015
    Naples fl
    25
    Re: Cloudy
    Yes. That way I am not dishing out money for things at pinch a penny
    13000 gal IG
    Attached spa
    Covered lanai
    Mar 2015
    Naples fl
    25
    Re: Cloudy
    Are any of you familiar with spa heater trouble shooting?
    There is a copper wire going from the heater which looks like a ground to the pump and then into the actual ground. When I turn the breaker over and position the valves correctly so the flow is going from spa to spa it seems the breaker trips. But heater makes a buzzing noise like it wants to work and no heat comming thru spa jets.
    13000 gal IG
    Attached spa
    Covered lanai
