Thread: New sand filter
    Dec 2009
    Central Massachusetts
    2,690
    New sand filter
    Looking to replace my old sand filter. Currently have a Hayward 18". Pump is a Pentair 2 speed 1HP. 14000 gallon pool.
    Was looking at either a 22" or 24" for a replacement. Any advice would be appreciated.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: New sand filter
    Bigger is better on a sand filter. 24" ought to be just fine though.
    Dec 2009
    2,690
    Re: New sand filter
    That's where I was leaning. I just wanted to make sure a 24" would work properly with the pump on low speed.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: New sand filter
    Quote Originally Posted by bk406 View Post
    The only time speed comes into play is during backwashing, and your pump ought to be able to dislodge things. If it isn't, no big deal. You just open up the filter and clean it manually with a garden hose once a year. Install unions when you're plumbing it in and it ought to be a snap.
    Dec 2009
    2,690
    Re: New sand filter
    Yes, I'm using unions for sure
