Thread: Tensioner bands on suction side line?
    May 2012
    Auburn, AL
    25
    Hey Folks,
    Springtime pump/motor changeout in progress. While committed to conducting PVC work, I figured I would address another problem.
    I've always had some sort of suction side problem with this pool. Most of the time it's OK with just a tiny amount of bubbles. However, sometimes the suction leak gets so bad the pump loses prime.
    So I dug up the suction/intake line and found two adjacent metal tensioner bands on the horizontal side of the intake line just before the 90 turn to vertical at the pumping station.
    I made a video and put it on FB. Here's the link:
    https://www.facebook.com/video.php?v...91871085916052
    If you have any comments, please share.
    McFlubbin
    18'x36' 30,000 gal IGP, Sand Filter, Intellichlor IC40 SWG, Main and Booster pumps with Polaris 360.
    Re: Tensioner bands on suction side line?
    That looks like flexible black poly pipe, which uses barbed fittings with hose clamps like those on the outside. Those connections can be very finicky sometimes, but once you get a good seal will usually stay sealed for a long time.
    Black poly was much more common about 20 years ago, compared to these days.
    May 2012
    Auburn, AL
    25
    Quote Originally Posted by JasonLion View Post
    Thanks!
    Can I assume the flexible black poly pipe runs all the way back to the skimmer?
    That is a very reasonable assumption.
    I personally don't like worm clamps but prefer t-bolt clamps as you can snug them down tighter without stripping...
    May 2012
    Auburn, AL
    25
    Well, since I have what seems like a small airport's worth of concrete apron...I'll wait until the situation is more dire.
    McFlubbin
