Thread: I would like to have the bottom of the pool re-plastered versus painted
    Hello - I am an owner of hybird pool, construction fiberglass walls and concrete bottom and noticed pool has lost of water over the last 5 months. I had a leak detected and fixed 6 years ago which was on the bottom drain (repair was done underwater and i am not sure what he used. I painted the bottom of the pool 8 years ago and now is looking shabby with peeling paint and am also seeing exposed concrete.
    Question - i would like to have the bottom of the pool re-plastered versus painted, is that an option? I have seen some comments that say it isn't an option.
    What other options do i have besides painting the bottom of the pool. Someone mentioned resurfacing the entire pool fiberglass - is that an option?
    Your feedback is appreciated?
    Thx
    Mike
    Re: I would like to have the bottom of the pool re-plastered versus painted
    Yes, re-plastering is an option. To be done properly you'll need to fully remove (sandblast) the existing plaster. You may be able to save some money by chipping away the weak spots only, but that seems to be a lee-than-optimal solution.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
