Thread: Rusted side wall - repair steps
    I have an above ground pool that has a 4" rust spot at the bottom of my side wall that is getting soft. It is below the skimmer. So, here is what I am thinking of doing. Drain the pool, leaving the skimmer attached. Pull liner back far enough to get to the rust spot, cllean up rust spot, epoxy a piece of galvanized metal to sit over the rust spot between the liner and the pool wall. Fill the pool back. I then need to replace my my skimmer. I am trying to not replace my liner since it's only about 4 yrs old. Does this sound like it will work? I was thinking if I left the skimmer attached everything would line back up.
    Dan
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Rusted side wall - repair steps
    Sounds like a pretty good idea to me.
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Use about three layers of duct tap over the edges of that patch if you do.
