Results 1 to 7 of 7
Thread: Taylor CYA test tube (#9197)
    ngc4900's Avatar
    Sep 2012
    Fredericksburg, VA
    56
    Hi
    I lost mine. Anyone know where I can order one online without having to buy new kit?
    Thanks
    Joe
    Indoor Endless Pool (IG). Aug 2012, 5200 Gal. Vinyl, Pleatco PWW10-M filters, Gecko controller, Laing pump, TFT 100
    Sep 2013
    Joplin, MO
    74
    Re: Taylor CYA test tube (#9197)
    Here ya go! I was looking for random pieces the other day too!
    http://tftestkits.net/CYA-View-Tube-p61.html
    -Paige
    Pool Owner since 2013 . 15'x48" AG Intex Metal Frame . 4500 Gallons . Intex 2100 GPH Sand Filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    There you go. Thanks Paige!
    Essential Links:
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    I believe the TFT cya tube is larger than the Taylor. You are probably going to want a TFT CYA mixing bottle as well http://tftestkits.net/CYA-Mixing-Bot...F-100-p25.html to go along with the new tube.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    That tube will work with either the K-2006 or the TF100, though it only reads down to 30. The K-2006 tube is slightly different, and is integrated with the main view tube assembly. The TF100 comes with a tube equivalent to the Taylor 9193, which reads down to 20. All three tubes can be interchanged in a pinch. They all use the same reagents, though they each use different maximum amounts of reagent.
    Various places sell individual Taylor parts, include Taylor themselves, TFTestKits.net, and a few other Internet stores.
    ngc4900's Avatar
    Sep 2012
    Fredericksburg, VA
    56
    Paige, Jason,
    Thank you so much. I have an indoor pool suspect my CYA will be lower than 30. Is the link that Paige provided correct?
    Thanks
    Joe
    I am sorry, I meant, the tube with the link above reads down to 30. Do I need I need a tube that reads down to 20? I use bleach only.
    thanks
    joe
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, the link is correct.
    Essential Links:
