Thread: Will adding chemicals to skimmer hurt SWG?
    Because I thought it would disperse the chemicals better, I added bleach and CYA at different times to the skimmer of my ABG. I mean a LOT of bleach... enough to get it to a FC level of 40 (to battle some algae). The SWG was not on at the time, but when I read the manual today it said specifically NOT to do that. Will it damage the plates or something?
    30,426
    Re: Will adding chemicals to skimmer hurt SWG?
    Regardless of your SWG, FC of 40 is potentially damaging to your pool surface....depending on your CYA.
    Probably didn't hurt a thing but it is a good plan to measure and dispense carefully when adding anything thru the skimmer.
    Why did you need 40ppm FC?
