Thread: Spa problems
    Spa problems
    Edit: Butterfly: Split from this thread: spa-problems-t9330.html
    My inground gunite pool with raised spa is new, 1 month old.. Everything seems to work perfect. I was reading this post on the pressure going up at the filter. When the pool side pump is on the PSI at the filter (Jandy) is about 10psi. When I switch the valves to the spa the pressure at the filter doubles. Is there something wrong?
    21 x 41 Oval AGP (24,000 Gallons)
    Sand Filter
    TF-100 Test Kit
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Spa problems
    I'm gonna be 'quick and cryptic' on this - check the filter! (when the pool was new what was the starting pressure?)
    Welcome to TFP!!
    Luv& Luk
    -Ted
    Re: Spa problems
    Thanks, this is a very informative site. The Jandy cart filter was at about 10 psi when the pool was started last month. Its about on 10 psi now when the pumps running in the pool. Its a 1.5 hp Jandy. When I switch the Jandy valves to the spa the PSI goes up to about 20 psi. Like I said earlier, everything seems to be operating perfectly when I turn the valves. The way the pool is plumbed, when I switch to the spa, the returns in the pool stop. Guess all the pump power and flow goes to the spa. Maybe this is what makes the PSI so high at the filter? When I switch the valves back to the pool returns, the PSI goes back to 10.
    Sand Filter
    TF-100 Test Kit
    Mar 2007
    4,160
    Re: Spa problems
    That's certainly normal Running the pump on pool mode has (probably) more suctions and returns, so when you restrict them down to just the spa, the pressure will rise.
    As for your original question, if it's not the filter, the others have given you the most probable causes
    Please keep us informed with your progress on this
    Luv& Luk
    -Ted
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Re: Spa problems
    I just had a spill over spa added to my existing pool.
    When I turn the spa on full boat, the pressure goes up about 5... From 20 to 25.
    This is perfectly normal as long as everything is working properly.
    Your system is probably running the way it is supposed to.
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
